Hello everyone! I am new to the group and I wanted to say hello and ask you for your opinion.
I am considering to change my rooflight at home, in the living room specifically. I have been checking the rooflights from Sunsquare, the pyramid multi pane (https://www.sunsquare.co.uk/skylights-and-rooflights/pyramid-multipane-roof-lanterns/) in particular because I am looking for an opening one. My question is... due that this is a opening rooflight and my roof has tiles (not too big)... is it possible to install this one in a roof with these characteristics or it needs to be flat?
Thank you very much. I appreciate your help.
Welcome.
12 minutes ago, Noelia said:
due that this is a opening rooflight and my roof has tiles (not too big) ...is it possible to install this one in a roof with these characteristics or it needs to be flat?
A little more explanation please.
You already have a roof light, and you want to change it to a roof light with opening panes of glass. Right so far?
Explain how the tiles on your roof might affect the new roof light.
Thank you for your fast response. I am not at home at the moment but the roof tiles look like these ones you can see on the picture attached.  Yes, I got now a non opening rooflight, it is just like a rectangular window and I cannot even clean it from the outside. That's true that the roof is not flat. It is more like a hipped roof but the slope is not too steep. Yes, my idea is to change it for a roof light with opening panes or at least, if it is not possible for an opening one. Thank you for your help.
Thank you very much for help. I'll research and contact several companies to compare which option suits me better. I'll let you know about their answers and the final decision.
I do not know if anyone has numbers, but I would think you should be at perhaps 1k-2k for the window, and about the same again to fit it ... not the 3k+ that other one was going to cost just for the window.
All I am saying is take a long hard look at your costs and check here. once you know what you want, someone may have a recommended supplier at half the price you get. It is that variable.
For cleaning, accessibility matters ... I can clean most of mine from the inside, both surfaces. Choose carefully.
Plan B is that your window cleaner may charge 50p-£1 a time to clean the outside, and may have a wotsit to do the inside in his van.
F
Edited by Ferdinand
