the_r_sole Posted August 5, 2019 Share Posted August 5, 2019 (edited) . Edited September 26, 2019 by the_r_sole Link to comment Share on other sites More sharing options...
joe90 Posted August 5, 2019 Share Posted August 5, 2019 I was intrigued by these stoves but in a well insulated house (not in the artic circle) it won’t be lit often enough to warrant it. Some on this forum will tell you your house will over heat with a wood stove, my wood stove is only lit in very cold weather and is surrounded by a large brick fireplace which sucks the heat in and radiates heat during hours after the burn. Link to comment Share on other sites More sharing options...
Thedreamer Posted August 5, 2019 Share Posted August 5, 2019 That's the plan with our stove, it's only going to be 4kw but surrounded by heavy concrete blocks in the centre of the house. Although realistically it will only be needed in winter. Link to comment Share on other sites More sharing options...
the_r_sole Posted August 5, 2019 Author Share Posted August 5, 2019 (edited) . Edited September 26, 2019 by the_r_sole Link to comment Share on other sites More sharing options...
joe90 Posted August 5, 2019 Share Posted August 5, 2019 10 minutes ago, the_r_sole said: yeah, but I've got a 60's bungalow! so the well insulated bit doesn't quite apply here!! Go for it then, my only worry was being able to clean the convoluted chimney run of soot!!!! Loads of info in the interweb on how to build you’re own. Link to comment Share on other sites More sharing options...
