susieo Posted July 19, 2019 Posted July 19, 2019 Hi, a real newbie here. We’ve just bought a house with a very decent 5x4.5m conservatory, double hipped, coming off two house walls. The problem is the polycarbonate roof, which we plan to have internally insulated with a multi foil (with air gap) and UPVC cladding. I wondered, as an extra waterproof and insulation method, whether we could also put some box profile roofing sheets over the top of the existing poly roof, with additional air gap and multi foil layer between. I know the best solution would be to replace the roof with a solid one, but hoped this might be an alternative. Would it work?
Ed Davies Posted July 19, 2019 Posted July 19, 2019 If you block out more than a certain percentage of the roof it'll no longer be considered a conservatory. That might have planning and building regs implications.
Carrerahill Posted July 19, 2019 Posted July 19, 2019 3 hours ago, susieo said: Hi, a real newbie here. We’ve just bought a house with a very decent 5x4.5m conservatory, double hipped, coming off two house walls. The problem is the polycarbonate roof, which we plan to have internally insulated with a multi foil (with air gap) and UPVC cladding. I wondered, as an extra waterproof and insulation method, whether we could also put some box profile roofing sheets over the top of the existing poly roof, with additional air gap and multi foil layer between. I know the best solution would be to replace the roof with a solid one, but hoped this might be an alternative. Would it work? The old conservatory conundrum. I'd take it down and build a proper room.
Gone West Posted July 19, 2019 Posted July 19, 2019 @susieo Hi, welcome to the forum. Is the problem with the polycarbonate roof that the room over heats or that the roof leaks?
