Apart from flex seals / couplers is there a better looking fitting for connecting cast to PVC then back to cast. Something like a multiquick
i I have to interrupt a cast iron stench pipe with a PVC 90 branch so would need 2 different fittings presumably. One to take PVC in female and one to take cast in female.
Brett Martin do a cast iron look range - the downside will be the tee will not look the same as proper cast but will be similar.
You can buy cast fittings still and they aren't as expensive as you think but cutting cast pipes can be a bugger ..!!
Oh no I don't mind putting a plastic branch in. It's just that the punters might think the band seals look a bit temporary. Specifically on about the fittings to join the two
Whether that fitting could be used upside down or would it be asking for trouble. If they're made to be water tight and stand a pressure test no reason they couldn't be used upside down?
Yeh I though of another problem aswell. You couldn't use one either end as you'd be working between two fixed points.
So it's either one of those on bottom and sleeve on top, or replace the lot. I'll have a look today see what I think.
