Weep Vents
LA3222
I have trawled this subsection and although it pops up now and then, it isn't clear what the requirements are with regards to weep vents in a rendered wall and how best to achieve it.
From what I understand if you have traditional masonry Block work for both skins then you can omit them.  However for those of us using TF for the internal skin they are still required.
So, as I understand it, where you have a window you would have a cavity tray over it which then needs weep vents at max centres of 900mm?  This could leave a load of ugly 'scars' all over the rendered surface.
Is there an aesthetically pleasing way of achieving this?  If not then how do you minimise the impact? Any particular way of doing it or brand of weep vent to use that is low profile?
TIA
Jamie
Weep vents always look awful on render
Mines B & B
i set one at either side of the window and door heads and ever 600 above lead
I carefully set ours at 18 mill proud to the block and rendered over them Leaving them flush with the render when finished Cleaning them out with a 2 mil drill bits
One site that we are doing the render on gas them all over the render and they look awful
@nod any chance y0u could take a couple of pics of yours near/far so I can get a feel for what they will look like.  Tried an online search and can only see horrendous looking ones where the entire perpend is open - looks gash!
Will do
The pictures show a site we’ve been doing since 2013
It embarrassing leaving wraps stuck out of the render
Some of the gables have them across the middle as well
Although the houses are for sale
A local housing association takes the surplus
Belt and braces
Overkill
Hope this helps
2 hours ago, LA3222 said:
@nod which type of weep vent did you use? As you say, they don't look great but I suppose it is something that will just have to be lived with!
I used Rytons Rytweep
You can get a verity of colours
 But I used Clear You can hardly notice them
That's good as they were the ones I had been looking at for their minimalist impact.  Would the buff have worked for you or was the colouring wrong?
Yeah the buff would have been fine
To be honest I had a box full left over from another job
Ok - useful to know.  Thanks for your input, I have a better of idea of how this will ultimately look.
Cheers
