Personal Information
About Me
DIY house renovater
Location
A remote corner of the UK
idontknowwhatiamdoing's Achievements
Member (3/5)
0
Started framing one room and thinking about insulation inside. I want to go with PIR but the cost and wait times are putting me off. The frame construction is 100mm deep and is surrounded by a aircrete / breeze block cavity wall outer shell. There is a 50mm airgap between the inner and outer wall for ventilation Interested to know what people have tried as an alternative to PIR, or is it a case of just bite the bullet and accept PIR is the only versatile solution currently in the UK?
Do you "really" need to skim Plasterboard?
idontknowwhatiamdoing replied to idontknowwhatiamdoing's topic in Decorating
Thanks, just discovered this Ames taping. Looks promising As @CotswoldDoItUpper said, its like hens teeth trying to find tradesmen at the moment...- 15 replies
- plastering
- gyproc
I am planning to do a lot of studwork this year with fresh Gyproc sheets. Since I am in a remote location, its been hard to get a Plasterer to commit to a few weeks to skim the rooms. Is there any alternatives I can employ to get some nice paintable walls? Any suggestions, or tricks welcome.
- 15 replies
- plastering
- gyproc
I am considering getting remotely controlled light switches for rooms. So I can have flexibility in figuring out where to put the switches and also save the hassle of wiring a physical switch. I can't seem to find anything about building regulations for RF/Wifi switches. Has anyone used these in their properties? Example below.
I have a stone cottage with an average of 800mm thick loose granite stones. I am re-doing the timber frame inside the cottage. I have a Tyvek breather vapor control layer for the warm side of the timber frame. Do I need a membrane for the cold side of the timber frame that faces the stone walls, if so, how do I add it when putting up studwork? Do you staple/tape it by section? I see them putting house wrap (building paper) on timber frame new builds, before the brickwork. So not sure how it works in a retro fitting for a renovation.
- 1 reply
- house wrap
- building paper
(and 2 more)
Been on the hunt for acrow props, cement mixer, STS drills from builders merchants, screw fix etc. Lots of places are out of stock or hiking their prices. When enquiring I have had the following responses: * Brexit delays * Suez Canal * Covid19 * An upturn in building projects (DIY and commercial) Anyone else experiencing issues getting tools?
If you can find out the name of the product, that would be much appreciated!
I am looking into replacing the roughcast on an extension (constructed in the 1970s) with Red Cedar cladding? I have seen videos online with timber construction buildings that have a building wrap layer applied before the cladding. Is this un-necessary for a breeze block construction (my gut says yes) However I wanted to check
I am a young guy who is not a tradesman, but I can graft and pickup things fast. I am fixing up a cottage in a remote part of the UK. It takes time to travel there as its not easy to get to. I have spoken with builders and other people to do work, but they are put off by the remoteness of the job. Which leaves me in a predicament. Work on it by myself with local help (unskilled), or get builders who are expensive to come and work on the site. I have been thinking though, surely there are some old builders out there or retired people who would like to consult over a long period? The location is beautiful, if that is a selling point. Do you think anyone would be interested in this, any ideas where I could find someone up for the task?
Yea, I looked at EPDM rubber (Classicbond) but its a tonne weight for my needs (62sqm) to do by myself. I am a young guy by myself, renovating a cottage on a remote Scottish island with no tradesmen, so need a system that I can install by myself or with some labour help Its water tight and can handle a coastal climate Can be self healing or easy to repair
