Everything posted by Adsibob
Anyone know where I can find jumbo sized MDF shelves
Adsibob replied to Adsibob's topic in General Joinery
The issue is that I want to have floating shelves, and so I need them to be thick enough so that we can drill into them to fit the special bracket (like this: https://www.bespoakinteriors.co.uk/shop/hardware/heavy-duty-floating-shelf-brackets/?gclid=CjwKCAiAjPyfBhBMEiwAB2CCImzyReyjIF9fMOAo77BcNbZDCijgkCIRMcf10d-FAZTcTYjV9DKAQhoCxvAQAvD_BwE) Although reading the details on that, it says minimum thickness of shelf should be 35mm. I’ve found a supplier that can provide 38mm MDF, but I don’t think they do as long as 2570mm, so I still have an issue. -
I thought getting MDF cut to size would be simple. Apparently not. I’m after primed MDF that is 2570 x 330 x 44mm Both the 2570 length and the 44 thickness are proving to be tricky to find from the standard shelf suppliers.
I finally got around to swapping some shower heads which we weren't happy with. When I took them off their supply pipes, I noticed that within the metal gauze filter that sits at the entry point of the shower head, there was a little bit of dirt. This was the case in both shower heads. Not a lot, just a four or five pieces of something; bigger than a grain of sand, but smaller than a grain of rice: maybe 2mm or 3mm in size. Is this normal in a completely new install? We've lived at the property for 10 months, so had plenty of use of the showers in question, so maybe this is not anything significant, but it surprised me as our connection to Thames Water was also completely new. Is this just general crud that will have got into our pipework at some point?
High boiler modulation after pressure loss
Adsibob replied to Adsibob's topic in Boilers & Hot Water Tanks
Update: installer has identified three small leaks across two of our four UFH manifolds. I'm not sure if these are "new". The water marks may have been there from day one, but he tightened the joints on three spots and said he was pretty sure this would fix it. So for the moment there is no need to flush the system with chemicals. -
Why is every hot water cylinder jacket out there coloured red?
Adsibob replied to Radian's topic in Boilers & Hot Water Tanks
Surely a big aspect of this forum is time wasting/procrastination/fun. I found this thread an enjoyable use of my time, even though nothing materially useful will come out of reading it. -
If this knitted UVC jacket came with this model, I would definitely get one. -
It’s possible they are all red to indicate that there is something hot inside: like the colour indicators on hot and cold taps. -
The installer is coming on Wednesday to do a more thorough check for leaks than I've been able to do, but i'm fairly confident there are no obvious leaks. It's obviously leaking somewhere, but not somewhere out in the open. -
what would this look like? -
Interesting. I believe @jack and I have similar units. I have a Brink Flair 400. Ours was commissioned by CVC and I’m sure they have the statutory amounts. Our air is a touch on the dry side in winter, so maybe I should turn the flow rate down a bit. On the whole I’ve been very happy with it. In the rooms where we have spent a bit more and have Lindab Airy valves/terminals it is silent . That includes in our master bedroom, en-suite, guest bedroom, study and living areas. In the other bathrooms and in the kids bedrooms we went for the cheap valves/terminals and it is just about audible. It would annoy me if it was in our bedroom like that, but nobody else has complained. Ours only really gets audible in our bedroom and en-suite when it is boosted, but even then it’s not that noticeable.
It’s because it’s the colour of socialism. -
We have discovered that some of our 2G windows are draughty. The draught is coming in at the corner of the openable frames. Quite disappointed given these windows were very expensive and marketed as highly energy efficient. I’m going to raise this with the suppliers (who also did the install), but I’m just wondering how easy it is to fix this without using those unsightly aftermarket products. Windows were installed about 18 months ago, and I suspect the problem has been there from the beginning.
Thanks. You are assuming a level of familiarity with these things that is a bit ambitious. For example, what does this mean: And how do I: -
Oh I see! Well not really, I’m blind as a bat when it comes to these things. here are two photos of my magnaclean. How exactly does one dose through this? -
In the end the modulation got back down to my usual reading in the 30s very quickly. I was just panicking (I’m an expert at that). Yes, we’re have a magnaclean fitted. Why would I need to dose more water? I’ve already topped up the pressure by turning two little valves that my plumber told me were for topping up. Weirdly, now that the house and HW have been heated and the boiler is off, it’s showing the actual flow temp as 74C. Not sure why that is. -
I have mentioned here before that our Viessmann Vitodens 200W 35Kw system boiler occasionally loses pressure. It happens every 8 weeks or so. @Nickfromwales recommended flushing the system with a special sealant and I’ve asked my installer to do this… still waiting. Yesterday night the boiler recorded a low pressure fault at 1124pm. We didn’t notice till 9am this morning when we woke up and realised we’re had no heating and the hot water was warm. I’ve topped up the pressure to 2.1, and this caused the boiler to start firing up again. I noticed that the flow temp slowly went up from 20C to 65C, it took about 10 minutes to get there. I also noticed that the modulation of the boiler was 98% to 100%. This has slowly come down to 55% as the boiler has been running over the last 40 minutes or so, but that is still much too high for normal. Even with every UFH zone on and our 2 rads and HW switched on, the boiler doesn’t go over 50%. At the moment, wet only have the HW, the two towel rads and about half the UFH on. Am I just being impatient, and will the modulation fall to around 35 or 40% eventually, which is where I’d expect it to be for this level of demand? Can anyone explain why this is happening Is it to do with the boiler running less efficiently until the whole system pressure is balanced?
Urgent need for a secure gate
Adsibob replied to Adsibob's topic in Networks, AV, Security & Automation
Machine gun assisted camera? Or better still, camera assisted machine gun? If anyone knows where I can get one, please let me know. -
Here is our design. in terms of additional countermeasures, shall I go for electrocution or just barbed wire? What about those fake guard dog sound emitters? -
Thanks, just been reading up on this/watching the videos and it looks good. What depth fixing would you use for 50mm of EWI on a single brick wall. I presume I need to anchor off the masonry and not just the EWI, so will 100mm fixings do? -
Sorry, you're right. It's Kooltherm K5 that we have, about 50mm worth, stuck onto very old masonry (it's a refurb of a 1930s semi) and then covered with a plastic mesh and a silicone render. But there is foil; it's just on the inside of the bricks, as part of a damp proofing fix that we implemented. -
I do get those alerts, but I turn my phone off at night, otherwise I'd be woken up by every fox and squirrel. There is a way to set it to just trigger for humans, but it doesn't always work. I'm not sure why that is. I guess the algorithms are only so good. We also have security lighting that comes on, triggered by animals, and that in itself might trigge the Ring. I'm not sure. -
I want to connect a PoE outdoor ring camera to a powerline (like this): https://www.amazon.co.uk/TL-PA4010PKIT-Passthrough-Configuration-AmazonBasics-RJ45-CAT6-Ethernet-LAN-Patch-Cable/dp/B07V2966DM/ref=psdc_429888031_t3_B01G5Q9E0O I have seen PoE injectors that can convert an ethernet cable supplying both power and data to two separate outputs: (1) an ethernet cable with only data; and (2) a power supply. Does the reverse of this exist, and if so, what's it called?
I wanted to check with my electrician before I start drilling holes into the external wall where the gate will be mounted, but he's not picking up his calls. I have external lights with PIR sensors installed along that wall, about 9' from the ground, spaced about 2m apart. As long as I'm not drilling in a line below these lights or a between them, am I save to assume i won't hit a wire? I could buy a sensor, but I'm not sure it will work, as the wall has 40mm or 45mm of insulation which includes foil and that may interfere with any sensor's signal. -
He only appears to come in to our side passage, not out. He must go out via somebody else’s property. Our house looks new compared to the others, and I made a point of making sure all our ground floor windows and doors are PAS24 rated. The side door is solid. But ours is the only house without a side passage gate, hence easy for him to come in to our garden, then access all of our neighbour’s gardens. I’m tempted to stake out the passage armed with a shotgun. But I don’t own a shotgun. -
I urgently need to put up a secure gate in our side passage. There have been some burglaries in our street this week, and today one of the victims knocked on my door and asked if she could look at my Ring doorbell footage. Sure enough, on the night in question (at 450am!) the bloody shit waltzed down my front steps and onto my side passage, completely unfazed by my security lighting coming on. He used my side passage to get into our garden, and from there jumped into the neighbour’s garden and stole some bikes from their shed. I have a quote for a steel gate but the lead time is 8-10 weeks. I guess I could install an off the shelf wooden one in the meantime, but was wondering if anybody knows any companies who could do something in steel more quickly, within a week or less ideally.
