Andeh
    2
Andeh last won the day on March 29 2025
Andeh had the most liked content!
Andeh's Achievements
Advanced Member
Advanced Member (5/5)
356
  1. Low right wire fence in front of it to keep the sheep away?
  2. Ours stopped once we confirmed demolished, then restarted with a new valuation when it was livable. We did a knock down and full rebuild, that 20% VAT saving was pretty helpful.!
  3. Urgh, so with hot tap open I depressurised it all. No water flowing. Applied electric pumo,which pressured it and hot water flowed from open tap. I kept going for 5mins,and never got a pressure rise in the cylinder. Just stayed at 0.95 bar. Is that a dead tank then?
  4. Thanks, I see the point now! I'll give it a go Friday when I'm next free
  5. Hmm, so the tap was left open for 60 seconds or so with cold shut off. I was pumping and pressure falling per previous message. However, when I shut the tap I was able to pump it up to 3 bar very slowly, but it seemed to be steady and touch wood was left at bang on 3 bar. Opening the hot taps and cold water back on, all seems to flow normally. Do you think I need to do anything now? Or redo the whole excersise with hot tap open fully for the entire duration?
  6. Well, i turned off the water... And opened a hot tap. I then proceeded to try and pump up the tank... Much to my horror the more I pumped, the lower the pressure dropped. Was starting to really worry. Then I realised the hot tap was still running, and I was effectively pumping the water out.... 😁 Tap closed, and back up to 3 bar... Fingers crossed it stops the water release now. Thanks for the guidance!
  7. Erm...... 🙃 Let me come back to you tomorrow once I've got home and tried it again. Thanks!
  8. I'm having a release of water down the discharge pipe/tundish, and as it's fresh water it's not from the heating circuit. The heating circuit suffered identical failure modes and glycol water release down tundish, a few months ago, due to a rusted through pressure tank. Replacing the tank with a recharged one resolved that issue. With it now reoccurring with fresh water it has me thinking my pressure tank has failed. I tried the nipple on the top, and pressing down on it didn't release any air... So I'm assuming it needs to be recharge. I've tried two bike pumps, but neither seem to work, I don't think they are pushing the pin down on the nipple... But the fact they manage it on a bike has me unsure? Is there a knack or technique I'm missing here?
  9. I also really like chemical anchors! 🥰 I'm almost disappointed I don't have more stuff to bolt down with it. It's a hard life post-build... When you run out of fun stuff to sink your teeth into...
  10. Keeping everything in folders, electronically ideally, with a systematic naming and numbering system is key I think. We only had 40-50 odd receipts though, all electronic originally.
  11. Yep, we found the whole system really good! Excel sheet list, evidence with matched titles to line item. Item, source, price, vat etc etc matched them over to their online system and uploaded, and submitted. Have to say, it worked really well.
  12. Our plant/utility room has the exact same 'problem'. Nothing you can really do about it, everything you listed gives off heat and its all stored together. Just makes for a very good drying room for the washing.
  13. We're 2 years in, cem floor no matting ... No issues!
  14. I'd be looking to seek forgiveness, not ask for permission here! Opening that can of worms of permissions and approvals l will take months and months and months and months.....
  15. I think (!) distance to road is governed by not blocking traffic whilst waiting for it to open. Ours is about 5m from memory.
