iSelfBuild
3 Followers
Personal Information
  • Location
    Dumfries & Lancashire
10927 profile views
iSelfBuild's Achievements
Regular Member
Regular Member (4/5)
90
  1. Never done a steel opening before (my house is still standing thankfully) but I'm not really sure how best to insulate... or fire board it. The column on the right is embedded in the old cavity (un insulated 55mm common brick cavity... looking at the workmanship and snots/ties it would be a bad idea to get blown in insulation) and the new 100mm block cavity has 90mm T+G Kingspan. On the right I was thinking 10mm aerogel, then fireboard over it. Insulated plasterboard is going left and right to give a flush finish and hide the column. The top of the beam.. stupidly I haven't factored in any room for aerogel or insulating... it's flush with the 1st floor/ceiling joists and depending if I have enough ceiling height... I will see if I can fit 10mm aerogel in but I will then have to pack down the rest of the ceiling to match in the old part of the house (new part is a cold roof and being insulated underneath anyway. I believe I need to fully encase the beam in 15mm fireboard... up the internal side, along the bottom face , then the other side has a timber trimmer bolted on and floor joist hangers, should I just go up and notch between every floor joist and hanger? The column on the left is internal so less issues with cold bridging (granted I know it's one big cold bridge and where it's bolted on pads...
  2. Does anyone know who is most competitive for aluminium clad timber windows these days? My jaw has dropped with the quote from my usual Polish supplier, especially for the angled feature balcony doors. I was hoping to use oak and will try Russel Timbertech as they used to be fairly competitve on oak but I will likely stick to pine. Out of the game a long time so I don't know which suppliers are good these days.
  3. Hmmm tricky one, I love it here - depends how much money I make though ultimately - 5 year plan is buying a farm with plenty of space to develop a small holiday park and run my other business's from. Taking myself back to the Scotland project and the 33m long x 3.6m retaining wall I built... which we had a concrete blow out. Not sure I want the hassle of a basement!
  4. Wee update - decided going down the planning and regs route is much more hassle than it's worth. Sticking a log cabin alongside the hedge - 2m away from boundaries on a reinforced raft. Single Wooden Garage TWIN (44 mm), 4x6 m (13'x20'), 24 m² Won't block too much view from the downstairs and makes absolutely no difference to upstairs or the new extension. Just need to convince my wife that adding a basement is a good idea for the big extension... even though I know myself it's a horrible idea that will be nothing but a headache and expense! Would love to build the garage myself but too busy with my business, thanks again everyone for your input and suggestions - always good to get others opinions and insight. Rich
  5. Definitely no windows planned. The hedge from their side is a mess. Cut back and it's all brown and dead. I shall replace it with a nice fence most likely.
  6. Only one way to find out... 🤣 There is also the neighbours garage on the right side which is part of their retaining structure - probably comes 1/3 of the way.
  7. Wondering even if i just take out the hedge to open up the sea views...could that cause any issues to the retaining wall which has been there 100 years or so?
  8. Money is no problem, It just might make sense to make a partial basement on my extension instead of the garage where I was first thinking. Extension is 100m2 don't quite need that big of a man cave though! I'll let the structural engineer advise on suitability just floating ideas for now 👍 If I do build something on the drive I will likely keep the garage at under 30m2 and 1m away from the boundary to avoid a load of bollox so it's outside of planning and regulations.
  9. I would be using a raft foundation so the 45* impact would be less than strip footings I imagine? Taking a closer look it looks like once I remove the banked up soil (there is also a dwarf wall my side) the drop to next door will be more like 1m. If I keep it 1m away from the boundary retaining wall by the time the 500mm wall height and 200mm raft epth it's going to be almost level with their side. Just my house to worry about falling into my man cave 😆
  10. Hadn't really considered that! It's just a stone wall - in good condition no cracks etc - but there is a big root structure of the Leylandii hedge which I imagine "reinforces" it all. I imagine the soil I take out will be more ground pressure than the new structure (as it will be timber frame) however definitely worth considering and looking into! Yes a door on the drive way and steps down.
  11. I'm just embarking on a large extension and as part of that I'm building a 30m2 home gym / garage. Please see my marvellous sketch... At the moment there is a large deep boundary hedge which is about 2.7m high - blocking stunning views over the seafront. I am wanting to be able to overhead press in the gym and need 2.8m ideally. So I wondered if I can sink down the base and build up with blocks (laid on their side up to above the driveway height. Fortunately next door it drops away about 1.5m so I'm thinking if I make a French drain all the way around and fill in the sides with EPS then crushed rock it should be ok... Silly idea or should it be ok? Floor level would be 500mm lower than the drive.
  12. Thanks again Mike! 2nd recommendation for Huws Grey. Think I paid £1.06 this morning for two pallets. Used to buy truckloads at £0.60 can't believe price of things creeping up!
  13. Thanks! What size cavity did you have with the 125mm PIR?
  14. Thanks, I'll be doing it myself so if I do the full fill I'd make sure I get the detailing right, I was going to use the interlocking ones as I know gaps are inevitable otherwise. Just trying to keep the overall thickness as slim as possible - It's only a tiny extension, original house is thick solid stone cottage so seems silly to go over the top. SIPS purely for speed - I've built DIY stick framed before and just CBA with the time it will take etc - getting the whole 100m2 extension up in a week and watertight is a massive appeal so I can plod on with the finishing.
