Laurence737
Personal Information
Location
East Midlands
Laurence737's Achievements
Member (3/5)
3
Yes we can’t see any evidence of a DPC on any of the other walls, if I tried to remove the cement mortar and repointed in lime would this be a better solution that trying to fix the ground based problem? and yes it is 9” solid brick
- 12 replies
yes, it looks like the brick surrounds of the air bricks were put in to keep them exposed when they installed the pavement.
- 12 replies
We’re not sure when the path was laid but it has been there a while (as has the damp and efflourescence) I’m not sure there is a DPC installed as it was originally a brick built church hall (1860 built) The path has raised up around a course of bricks.
- 12 replies
Hi Everyone, we are trying to resolve some damp/efflorescence issues with our 1860’s property. we are getting high damp readings and efflorescence on our external road facing wall, I think the problems stem from the fact that the council put in a small pathway abutting the external wall and laid asphalt between the house and kerb, this has raised the level against the wall and is causing water to sit in the gap between the asphalt and brickwork resulting in the wall being constantly wet. we also have an enclosed gulley that may be adding to the problems. What would be the best solution for this, I imagine cutting a drainage gulley in front of the brickwork? But guess this would have to be a gravel soakaway? As the air brick surrounds would block a dedicated drainage channel? I would also like to remove the enclosed gulley and replace it with an open one that is easier to check for blockages/clean, is this a viable idea? I also think that we have some concrete pointing in the brickwork, would it be worth the time/money to get this removed and repointed? Thanks a lot for any feedback/advice!
- 12 replies
We’re looking at a double flat vertical column rad I guess for those outputs? Our style pref is the flat bars.
Hi Everyone, I need to pick up a 2.2-2.5kw flat panel column CH rad and wondered if anyone had any recommendations? Struggling to find something suitable. Thanks
Thanks for that input it’s really helpful, as far as I am aware without having the instructions it seems that the system is similar for LVT to the Wunda boards, where you install a 7mm HDF board over the top to fix the laminate to? what sort of W/m2 would you say I should be looking for at T50?
Hi Everyone, I wondered if anyone had any experience with the Nu-heat LoProLite retrofit wet UFH system? We are looking for a low profile system to retrofit into our property and have around 30mm from the current floorboards to the existing sill heights so we’re thinking of using this system and 8mm LVT. Thanks
We have the space to store them securely which is fine, our builder told us his suppliers are expecting a price rise of around 10-12%?
Hi Everyone, We are starting the major part of our build/renovation late April, however our builder has informed us that his suppliers have indicated that they expect a significant increase in the cost of building materials (particularly timber and insulation). He has suggested that we bulk purchase the materials we require and store them, this is equating to around £17k in materials, he proposed we do it in chunks of £5k orders to maintain trust. Has anybody else got any experience in this? Obviously we are a bit hesitant to put up this money before work actually starts. So any advice or comments on this would be greatly appreciated ??
Thanks for that, what would you recommend as the best way to insulate it and keep it all dry?
Hi Everyone, I’ve finally got around to converting the room above our double car port into a functional office. I just had a quick question about insulation, the floor of the office is timber and below are the joists that form the ceiling of the car port (see photos) I just wondered what the best way to insulate this space and keep it dry? I was thinking of PIR between the joists, a waterproof membrane below and then cover the bottom with MDF boards? And what is the best way to insulate the sections with the braces? Thanks
Thats what I thought, I just got my head in a mix with the way it’s phrased and had a small panic ?
It was this part Escape from upper storeys a maximum of 4.5m above ground level 2.2 See Diagram 2.1b. Where served by only one stair, all habitable rooms (excluding kitchens) should have either of the following. a. An emergency escape window or external door, as described in paragraph 2.10. b. Direct access to a protected stairway, as described in paragraph 2.5a. 2.3 Two rooms may be served by a single window. A door between the rooms should provide access to the window without passing through the stair enclosure. Both rooms should have their own access to the internal stair. As I’m not sure the room will comply with that statement?
Hi Everyone, Having a bit of a head scratch moment and wondered if anyone could shed any light as to wether my plans to move our bathroom upstairs would comply with regs, particularly part B. The room is directly above the existing bathroom that has a door leading out to the main gallery landing to the staircase which leads to the open plan kitchen/dining/living space and has a small skylight fitted at 1.7m sill height. would this room comply with regs? Thanks
