@Redbeardwe shall see, but I suspect it’s BS. The windows are engineered word, but they said not to install until wet work has been completed on the house - screed, plastering etc. Again I am slightly mystified.
Hi folks, I have fitted new windows to my new build, and noticed that the wind whistles though the vents, even when closed. Is this normal.
the window manufacturers say that the noise will settle down when the heating goes on. Not sure if this is BS.
any ideas
Cheers
aronite
@Russell griffiths thank you very much for all the information, much appreciated. What type of concrete did you use please? The reason why I ask is that I used semi-dry concrete on another job, and it was permeable and just let the water in around the tank I had put in. Cheers Dave
@Russell griffiths thanks a lot for the photos Russell ! Am I right in thinking that you created a concrete box around the tank and then filled that with concrete? Cheers Dave
@Russell griffiths morning. Did you dig a hole, insert the treatment plant and then encase it in concrete? Or build a concrete box to put the plant in, then place reg tank in that, and then fill that with concrete? Thanks a lot, Dave
@Russell griffiths that’s impressive ! What type of concrete did you use for the “box”? I forgot to say, water table is almost up to ground level at wet period in winter cheers, Dave
Cheers Russell. Really appreciate your post. Can you give me an example of a “really good plan” ? My main concern is lateral hydrostatic loads, and how to prevent them. Cheers, Dave
Hi folks has anyone got any experience in installing a Clenviro Sewage treatment plant in a high water table? If so what thickness and type of concrete did you use please? Thanks Dave
It’s often not easy to do, and very expensive to boot. It’s a ludicrous requirement for a single dwelling like mine that in the middle of a 2 acre plot.
Hi folks. On inspection the seals from the risers in 3 inspection chambers were found to be missing, hence the water ingress. The seals were inserted and glued into position. We then poured about 30cm of concrete around the entire inspection chamber. Problem no solved, no water ingress. Thank you for your help.
