mads
Everything posted by mads
  1. Why not get the builders to put conduit in and then pull the cable yourselves?
  2. Valid points. I guess for me, its also the sustainability aspect of it and reducing the need for potable water. Can an IBC be buried? Probably, but would suggest very shallow with little weight on top of it and somewhere with no vehicles driving over it. My intention was for the RWH tank to be in the driveway so need to be more robust than an IBC.
  3. In your view, is that also the case for a sewage treatment plant which discharges to watercourse? I don't have mains sewer and no soakaway due to heavy clay. Without hijacking the OPs thread, my reasoning for installing one is with a 6 person household, with 2 older people and at least 1, if not 2, working from home, there will be higher usage compared to a "standard household". Plus gardening, car washing etc. soon adds up on a water meter.
  4. personally, I think it is a good half way house between cat5 and cat7 (I don't see a residential need for cat7/8 unless you have a MASSIVE house). It can be more expensive than cat6 but I find most people are not comparing like-for-like as they compare unshielded cat6 against a shielded cat6a (I just re-checked on Cable Monkey website and costs were comparable in my view). I agree with @bmj1 that some of it comes down to how long the run is and I did caveat that if you can afford it you should. As others said, make sure you have enough runs into a room first and then consider how much budget you have for determining cable type. In my last place, the lounge had 4 network points for TV, AV etc and then a WAP for the wireless devices. Re: future, the things I see requiring more data transmission are high def TVs mainly but who knows what the future might bring. I am thinking real-time streaming of CCTV with AI might require a bit more data too.
  5. @simonr, I'm interested what the Kingspan control system was meant to do? And if the new pump covers it all? Also, did you put a header tank in somewhere to stop the pump activating each time there is a toilet flushed? Thinking about noise in the middle of the night in the house if someone goes to the toilet.
  6. If the conduit is wide enough then it shouldn't be hard. You can have bends but not sharp 90 degree ones. Ideally sweeping ones. I am planning for 50mm conduit for pre-made fibre cables to allow for the jacks to not get stuck. I doubt you need so wide for Cat6a cable. Sounds like you are being fobbed off as they don't want to put/have the ducting as they then need to be more careful.
  7. If you can afford it, go with the Cat6a now Definitely terminate and test after cables are laid. Leave an extra half coil length so when you cut off the plug to properly fit you have enough length left. Yes, terminate after you have run the cables. Its a PITA to run with the plugs attached. Fit them afterwards.
  8. I'm hoping not to be needing to ever get under the flooring But on a serious note, realistically how much "empty space" will be under the floor given recommendation I have seen is 225mm between floor underside and the ground. Though writing that just now it does feel like unnecessary excavation when I consider the ground floor will be 195sqm.
  9. I like the idea of hiding the APs above the plasterboard. I have explored recessed brackets for Ubiquiti APs which are now readily available compared to when I did it 7+ years in previous house.
  10. Hello! My architect mentioned that the SE is proposing a block and joist foundation rather than a concrete pad (which is what I was expecting) Just wondered if there is much difference between the two in terms of benefits, costs, etc? Re: ground conditions, we live in an area with heavy clay (awaiting geotechnical investigation report)
  11. I would agree with bmj1 on this. Its what I did in my last house and plan to do the same again (though am also routing conduits for fibre in future, as well as LIFI points but thats for another thread) It is not hard at all. I would suggest you save your money and do it yourself. I ran 1.5km of data cable in my last house and had 30+ connections. I got my wife trained in terminating the connectors (piano fingers) and she was a pro by the end. Buy some decent tools and tester - will cost you no more than £50-60 total and they are useful for any future uses you might have.
  12. Thank you all for the warm welcome Yes, planning permission already granted. Took a year to get to but done so now on to the more exciting, and nervous, phase of more detailed design. Yep, ours is a 1960s bungalow which has been extended a couple of times and done with varying quality and thought. Our neighbours when we moved in had done the same and said similar to you so decided to go for it. Yep, absolutely made it clear to the architect that we are not aiming for a passivhaus but want to adhere to the principles so making sure we are covering those elements and not compensating with technology. We are going with traditional block and brick. Decided against SIP as not convinced on its longevity personally. We are also incorporating some metal cladding into the design. Oooo... will have to follow your build closely and take notes. Planning is all done and tbh other than some minor alterations, and a to-and-throw with highways, it went through as we had designed. We made sure we got support from local parish, which I think helped. Plus there was some precedence from our neighbour who did the same 2 years ago. I hear what you are saying and to be honest, if I had the opportunity I am quite certain I could PM it myself. I grew up helping my parents do up properties so learned a lot. The challenge I have is that with a young family, we do not want to be in a caravan on-site for longer than needed. And I think I can bring more value by earning money to fund the build rather than do the PM. Perhaps once this one is done, I can convince my OH to do another one
  13. Fantastic - thanks for finding and sharing. And agree, they look good. Good shout on the sliding vs bi-folding. Looking at juliet sliding doors on ground and first floor
  14. lintels that can incorporate the cassette is what I am after so if you do find the supplier, that would be helpful. re wired vs wireless, I was planning to go with wired but have them connected to Home Assistant so I can control from my phone. thanks for sharing the benefits of Venetian blinds. Makes sense. I think it’s my aversion to them from an aesthetic perspective is something that could be overcome if can find some that don’t remind me of the internal ones I had in my first home.
  15. I was looking at blinds that still let you see through them rather than create any visual impairment of the views
  16. Hello all, The south and west sides of our self-build will have fairly large triple glazing, which is great to let light in and enjoy the sunshine. However, it does create the issues of solar gain. I want to derisk this as part of the build, rather than afterwards by installing motorised external solar blinds. I’m not a fan of the Venetian blind style and prefer the fabric roller blind type on wire or guides. I have been looking around and they all seem to be bulky and not “hidden”. It is a traditional brick and block build. Has anyone fitted blinds like the above and part of the fabric as it were? I saw someone one here had done it for a wooden cladded structure but not found anything for brickwork. The walls will be 350mm so I can set the windows back if necessary. Thank you.
  17. Hello all, Been lurking a little while and more recently joined to be part of the community. We moved into our property in late 2023 with the initial intention of going up and making it a two storey bungalow. However, we quickly realised that given the amount of work that needs to be done (full rewire, new heating, lack of insulation, poor layout and flow, poor plot siting, majority of internal walls and some external to be knocked down, new roof), the compromises we are likely to have to make, the unknowns as we start to strip it back etc, we have decided to knock it down completely and do a rebuild of a two storey house (first timers with this). The architect has taken a fabric first approach and we are also going with the full technology spectrum i.e. PV + storage, EV charging, ASHP + UFH, MVHR, as well as ensuring it is fit for the future e.g. conduits for internal fibre runs. Not being in any of the trades required to do a house build (I work in data and AI), will be getting a main building contractor to do the majority of it (we are hands-on so will likely be doing some things ourselves). Also, I like to get involved so increasing my knowledge in various aspects to be able to make as many of the right decisions that we can, hence joining this forum and benefitting from the collective wisdom (and hopefully contribute where I can to others' journey :)) Thank you in advance and apologies for any less-informed questions
  18. Now known as 21 degrees. They only do design and supply.
