lizzieuk1
Everything posted by lizzieuk1
Is that because Isoquick use a level, constant 200-300mm concrete slab rather than an integrated ring beam Ian? Have had a high level cost from Greenraft for material supply, worth asking them for design?? My worry is the SE doesn't have enough experience and will just design the easiest option, which, inturn will mean its sub-optimal. Don't want to upset the SE but need a diplomatic way to tell him we're going elsewhere for the raft 😬
OK, so the SE has come back to say happy to detail a raft for us. I asked for an example he has done before but, his reply was: "I have done insulation below ground bearing slab for the industrial building working in the previous company and I do not have such a detail. I have been running my company for 6 years and no one from my 1200 projects has done XPS below the slab. It's a shame because this is a correct way to insulate the building. You should assume 200mm XPS if you wish to have a well insulated building." Then he's put a link to Isoquick as an example of a foundation he feels is ideal. Now, we're not suggested he can't design one but, a bit concerned whether it will be the best option. Help! Should we go to one of the raft suppliers or elsewhere to get it designed?
Many thanks Iceverge, that's a great post.
Thanks Nick, its not easy, I've been trawling for hours hence the post, thought there may be someone on here who's done similar.
Yes, that's what I was meaning when I mentioned mock sash, there's some much nicer ones too that actually look like sash windows but are on standard casements. But, I can only find 2g ones, hence the question of is 2g(lower u value) with good AT preferable. Just wondering how a 2g compared to 3g will affect our efficiency.
That was my thought too but, are there any good options for the Georgian proportion windows?
I had a feeling that would be the response 😆
On a slightly different note, any opinions on which is more impactful, u-value or air tightness?? Looking at windows, likely options are upvc 2g mock sash or (possibly) 3g or traditional sliding sash - though struggling to find any with 3g as an option! Thinking mock will have far better AT than trad sliding.
Hi all, So currently scaring ourselves with the new build budget and trying to find a good solution for windows. We have a georgian type build design, so sash windows looking to feature. However, aware of the poor air tightness and, it seems, lack of 3g availability for a sash. Wondering if anyone has any good solutions, not averse to a good mock sash in wood effect upvc, but are there any 3g versions? Ideally not timber as, going forward and getting older, maintenance has to be a consideration.
Sup roof on masonry build
lizzieuk1 replied to Lewis88's topic in Structural Insulated Panels (SIPs)
Ah that's good, we're in Lincs -
Crikey that sounds pretty good Nick, so we could build to 1st fix and then get them in without needing to do any parge coating at all?
Think the blown cellulose is our preference, we don't have shallow pitch and will have blue slates & solar but still like the cellulose option. Only issue may be if we can find a supplier so we can diy it, though not sure how much cost saving to be had compared to supply & install option.
Amazing, thankyou 😊
It is used quite widely in other countries though so, there must be positives that drive the usage.
In preference to posi joists? Then underlined with insulation for cold bridging?
Wowser, thanks Nick for such a thorough run through of all that! As you say it is worth asking the question re cost and a conversation around woodcrete to see if that approach is a cost effective/practical option or if parging first would be better. (Obv they will want to sell as much product as they can so I guess critically appraising their answer is in order) The one issue I could see for us, is that we have been looking at a posi joist roof structure & blown cellulose which, sounds like it may not be suitable for that system. The cutting & fitting of pir between rafters (and now a need to tape all sides) is so painful, not to mention the cost, so we're looking for a better way!
It sure is! Thankyou buildhubbers, you are all a vast knowledge base and I really appreciate your time with my questions!
Looks like a clever system Nick, any ideas on cost?
Well done JohnMo, looks like you've set the bar high!
For a stonemason the tolerance is 3mm so, I'm sure hubby will be all over that, it may take longer but he won't let it slide!
Thanks JohnMo, that makes me feel far better! This is what we're hoping to achieve so really glad you have successfully done the same.
Gosh I'd hope not, they're 1/4 mile away 🤣
I'm wondering if we just fix a slip board without insulation whether we could then level them out as we installed. Not sure if moisture behind those would create an issue 🤔 if there are drain holes or something at the bottom. If not maybe we make sure we seal all round them.
