AartWessels
1 Follower
Personal Information
  • Location
    Aberlour
AartWessels's Achievements
Member
Member (3/5)
15
  1. Eclisse is one of the most renowned brands for pocket doors. All our internal doors will be pocket doors, but haven't installed them yet, so no feedback yet.
  2. 150mm can be quite a job to get in if it's tight. But yeah in principle that's what you do. Measure top and bottom space, might not be exactly the same. Measure each gap by itself, they might not be exactly the same. If you cut the plate wider, I wouldn't do more than 1mm wider. It's a b##ch to squeeze it in between the rafters if it's too wide. And it's even worse to get it out again if you want to reposition it.
  3. We've put up polystyrene blocks around the 110mm OBS coming up for the shower, to block the concrete and allow fitting the drain.
  4. It's hard to understand that there are apparently no WRAS approved frost free taps like the Schell Polar II or Kemper Frosti. I'm not from here originally, so I'm used to some different materials, though what could be wrong with products like that? Backflow protection is included, they provide proper frost protection, make fitting the tap a breeze.
  5. I found using Buildstore as a broker to be very helpful. Our conditions are complicated, being here on a visa, only since 2 years ago, and wanting to do a real self build in Scotland. Buildstore made sure to approach lenders first, to see if there would be any willing to accept us. Then they made sure we would lend solely on my income, as per our request. Then they kept us right in preparing all the paperwork. They prepared the costing, which corresponded with mine, but presented in a way the lender wants to see, etc. So yes, costly, but worth it I think.
  6. We had the formal offer the day after the valuation was done. Going from formal offer to money in bank account depends on many things. Are all conditions set out by the lender met, such as structural warranty, site insurance? How quick will your solicitor act in terms of title deeds, etc. So could range from a week to a couple of weeks or more. Depends mostly on what you have prepared?
  7. That's it. Works wonders in a rural environment, and an ROI of around 10 years if you included a pump, or less than 7 years if you don't. And maybe even less if it is in a location without any existing infrastructure.
  8. Although I agree that is factually true, I don't think in real.life it matters that much. With that, I mean, there are so many factors in the actual environmental conditions,that you can't accommodate for all of them, not even when designing. KISS. An oversized track will hardly ever fill completely, so the tank must fit to the roof surface. Only water from the roof areas should go in. Keep your gutters clean. That has a very big impact. Clean the inflow filter regularly. Again. A big impact. In a big storm, you won't catch it all. Many reasons why not, but mostly because the time of year these usually come (the wet time), when your tanks are filled already anyway. Now, if you don't intend to use it for the house, but just for the garden, allotments, greenhouse, etc., the story changes. Using a catchment basin, IBC containers, etc. change the ROI dramatically I'd say.
  9. Maybe. I'm not against storing rainwater, I just think using it in a house is not a case with an ROI. In our new build we'll store it in a wildlife pond.
  10. It's mandated to prevent water problems. Prevent a bit of flooding, etc. And then 'sustainability'. I don't think it's hitting either of these targets. Doubling the tank size depends on the size of your roof. Still, watering the garden in summer will suck it dry in 2 weeks.
  11. I moved here from Belgium, where rain water harvesting is mandatory. We had a 5000L tank installed. Water costs around £2.20/m3 there. We used rain water for laundry, toilets and the garden. There is however absolutely no way to get an ROI, or at least not in Belgium. A major part of summer, the tank will run dry. In the wet periods, it will be full, and therefore the rain water will overflow to a drain. So the theoretical volume of rainfall can not be used, as it cannot be harvested in practice, and part of the year you will have to fill the tank from mains water to keep toilets and laundry running. Anyway, that's just my practical experience.
  12. That's what I've been looking for as well. Not been lucky yet, but I guess I will be at some point.
  13. No, I don't think so. As far as I am aware there are no grants available here for self build.
  14. That is what an architect is for, partially...
  15. I get that, but the exterior part of that insulation is just a former and will be removed after the pour as far as I understand. So I guess your other suggestion is better, albeit a bit messy and indeed requiring lots of trust and/or oversight.
