Lofty718
Lofty718's Achievements
Regular Member
Regular Member (4/5)
33
  1. The idea that CO2 is bad for the planet is a total hoax anyway. CO2 gives life to the earth and is the reason crops thrive The goal here is to use farmland resources to power the new AI data centres which need disgusting amounts of water and energy. Hardly the actions of people who care about so-called climate change
  2. Architects are often totally clueless about a lot of things, do your own research and save a fortune😁
  3. I don't think you have any right to withold money in this instance. Just sounds like you are looking for an excuse to reduce the final bill for something that happened early on and that there was no way around.
  4. Interesting regarding range rating, my Vaillant is 30kw range rated down to 6kw and still cycles heavily, really annoying a year after I bought my boiler Vaillant then released the new ecotecs that modulate 1:10 rather than 1:5 You do know that cycling is not the end of the world though? as long as you get a burn time of over 12 minutes or so each time then not much efficiency is being lost at all.
  5. How much are you going to charge Viessmmann for making you come home to a cold house?
  6. 45c is too hot for UFH, mine rarely gets above 40c (controlled by esbe) but most of the time it's in the 28-35c range If you size all radiators to run at 35c that might work, alternatively get an esbe controlling the UFH but I think this might require hydraulic seperation (CCT) and a seperate pump. Seems risky though and maybe difficult to get things comfortable, UFH all round run off one flow temp would be best
  7. This plan makes no sense, better of getting a UVC with a system boiler that runs on weather compensation
  8. I have the same boiler and controls and know them like the back of my hand. Many installers don't understand them very well they just bodge it and scarper Post your installer menu settings. I run a curve or 0.3 for radiators What is your setup like, radiators only? UFH? Unvented cylinder? Is it running on PDHW?
  9. On my Vaillant I run two different flow temperatures/curves for radiators and UFH. But the only way to acheive this is with electronic mixing valves (esbe) and hydrolically seperated pumps for each zone `i wouldn't want to do this with.a heat pump though, I would design UFH and rads to all run at the same flow temp
  10. Dow corning 785 I wouldn't use anything else
  11. You are missing the point, heat pumps shouldn't turn off once the heating demand is met because it means when they turn on they will need a higher flow temperature to acheive the desired result which in most cases means a lower COP and the heat pump having to work harder. I don't know any installers that use this setting, only as a last resort to fall back on. I run sensocomfort on my Vaillant boiler and still don't use adaptive, I don't want the boiler and pumps shutting down. I use less gas when on constantly and trickling a small amount of heat into the house. Curve 0.25 for UFH and 0.35 for the radiators
  12. Adaptive is not the most efficient, when I have it turned on it has the curve higher than I would set it manually and tends to overheat the house Adaptive only works on the 'EXPANDED' mode which does not utilize weather compensation and low and slow heating, on expanded mode the heat pump will cycle more as once the heating demand is satisfied it will turn the heat pump off rather than the other modes that keep the heat pump on constantly never turning off when theres a heating demand and trickles low flow temperature heating into the house. Read the manual, all of this info is in there. An adaptive curve may be suitable for a small number of properties where you cannot get things calibrated properly with either full weather compensation (best option) then the second option would be active (weather comp with room influence modulation) .. expanded with an adaptive heat curve is the least desirable option for efficiency... but might work for some houses.
  13. I have an unvented cylinder and a mixture of radiators and UFH. Many people have this setup and it's no problem at all to have one boiler that does everything, these installers sound like total scam artists trying to fleece you and the work is substandard, you should get rid of them and do not pay a penny more. Being qualified means nothing nowadays unfortunately, but you are in the right place now to get sound advice on getting it done properly
  14. That's insane, why do you have another boiler i'm sure your system boiler alone would of been more than capable of running all the rads and the UFH!
  15. Is your house fully UFH? if so then that is highly inefficient and you could run the heating straight from the boiler with no inteference from pumps and mixer valves (which are crap old technology anyway) This could of been a much cheaper install, by scrapping the mixer, pump and actuators and just getting a VRC720
