Del-inquent
Everything posted by Del-inquent
  1. Yes, they'd like all the modules and fronts to be the same size. Cold eaves, yes. Modules are clad with 150mm PIR on the backs, and 50mm stuck between each as they go in, so pretty snug. The plate (I can't remember the name for it when it's used like this! Binder?) is just a 4x2, there isn't anything below at all. I'm going to try and get a proper look at the Purlin, at the moment I can only see an edge of it!
  2. Just been asked if I can help with something but I'm not sure on it, so looking for a bit of guidance. In their loft conversion, a stud wall runs from the purlin down to a plate on the floor joists. Half the wall has studs at 400mm centres, half has 600mm. All studs are 4x2's They'd like them all to be 600mm so they can put storage in. I'd assume the wall is spreading the load out, but why they have a mix of centres is what is concerning me. Can those 400mm centred studs be replaced with 600mm?
  3. I've had mixed messages on this. Originally I was going to go for PIR, but several people with far more knowledge on this than me (not hard, my knowledge on it could be written on a postage stamp...) have said that whilst the base figure of PIR is much more effective, movement, gaps, difficulty in effectively sealing in a retrofit with warped and twisted joitss etc drop the efficiency quickly, and it's not breathable so can introduce problems with moisture retention against the joists, which does concern me as last thing I want to do is bring more problems to a property that has plenty already lol
  4. This is possibly a really stupid question seeing as I couldn't find anyone else asking it with a search, but... Our ground floor is suspended timber floor. The joists are 100mm deep. The void below is 100 - 150mm. I've got to take up several floors for other reasons and as there is no insulation under there I thought I'd put some in. I am looking at using rockwool or similar under there using a membrane draped over the joists. If I made the drapes deeper, or tacked some timber underneath the joists, I could put 150mm insulation in. But would that actually achieve much given the joist depths there currently?
  5. Just in terms of what alterations would be needed, it's construction has been modified a couple of times and made it awkward to do without significant disturbance, and we're living in it.
  6. I definitely agree it's not ideal putting it in a cupboard, the problem is the next most suitable place is a long way from it and difficult to route to. One thing that both electricians have said is that they will have to mount a new CU at current regs height - is that not the case? If it can go literally anywhere, it could move just 15cm... to the other side of the wall, in my office, but only if it can go up at the same height it currently is (2m)
  7. Explanations were “thin” shall we say. He was pretty adamant that it had to have clearance around it and couldn’t be within a kitchen cupboard. ideally I’d move the supply, meter and CU elsewhere but the budget has been swallowed by a nasty surprise
  8. It looks like we might be having a rewire on our new place. I've had a chat with a couple of electricians as the current placement of the consumer unit it is less than ideal - it's in the kitchen, in a rather awkward place and severely hampers the layout of the (not particularly big) kitchen. Electrician 'A' has told me that it would be fine to have it within a kitchen cupboard and that there are no requirements for clearances either side of the CU. Electrician 'B' has told me that's not permitted. I've been searching but can't find any guidance on it. Keeping it within a reasonable distance of the supply / meter, it would be very simple to put it within a 400mm full height cabinet (which also fits in to our favoured kitchen design), so I'd like to believe Electrician 'A' but... well I don't want to have a nasty surprise!
  9. I've drawn them up from others specs, not done the calcs myself, I'd be getting some help on that front from a friend.
  10. @ETC does the above give enough info to form an opinion from or would you need to see more?
  11. They're very rough and basic at the moment as I can only get round there occasionally at the moment to work out dims, but in essence this is the plan. As-is at the top, as intended at the bottom.
  12. I'm looking for some examples of building control submissions for a dormer extension. The property (chalet bungalow) currently has a small (2.4m) dormer on one face of the roof, I'd like to extend it to about 90% of the width of the roof. I have significant design and drawing experience, but zero experience of the new part L and reading it is driving me slightly insane.
  13. I'm just giving my brother a hand getting ready for a new patio door to be installed. The manufacturer has sent the spec and sizes over. Due to the way it's specced (to give an almost flush cill to the inner floor level) and to match another patio door nearby, a row of bricks needs to be removed at the bottom of the opening. The door spec requires 10mm tolerance all round, however removing the full course of bricks gives too much clearance - with 10mm above the door, there will be 35 - 50 mm below (lowest course of bricks is not level, old house) I'm thinking of just laying down a bed of mortar on top of the newly revealed course, running from 25mm one end to 40mm other end, to level it and create the correct dimension. Any flaws in that plan? Mortar work is "not my strong point" so thought I'd check. We're not fitting the door, the supplier is, so I don't want them turning up and saying it's not suitable for reasons I've not thought of.
  14. Long story on the builder... complete and utter cowboy that frankly I wouldn't let back near the property ever again, if it were mine, and I'd be pursuing them through the courts to get money back as well. Sadly not my shout on that, I'm just being asked if I can help clear the mess up. IF we can avoid taking the floor out that would be ideal not just on a cost basis, but also "save my aging back" basis. Do you think a self levelling screed on top of the oversite would be a bad idea or a "bit of a bodge, but it'll do the job okay" idea? What's the minimum thickness and any additional bonding needed?
  15. 2.4 x 2.8m, the breaking out option would be a lot of hard work by hand I think!
  16. I don't know if they need screed is the honest answer! The insulation is under the slab apparently, I believe it's Celotex PIR as there was a lot of that sat around, not sure on thickness. The oversite is... "a bit lumpy" to say the least, so would need *something* doing first. They're planning on tiling the entire ground floor so could the tops be knocked off the worst of the slab and a self levelling compound take care of the rest?
  17. Just pondering on an issue with a relatives house, trying to find any plausible solution. Property is currently being extended both sides of an existing room. The extended floor slab on one side has had too much concrete poured, its about 40mm higher than the other side. Problem is, the property had rather low ceiling height in the first place, and losing that 40mm isn't great. The room isn't that big, 2.4m x 2.8m So my questions are... What would be the most efficient/effective/remotely possible way of cutting off/grinding off/skimming off the overpour, if at all possible? Is there some sort of "super screed" that can be put down a lot thinner than usual?
  18. No PV at the moment but I have been given notice that some might be available in the very near future at a very, very attractive price. I'll have a look at the Vaillant 938, cheers. The SA is "rather pricey" as you say but if it does the job well, I'm not adverse to getting one. As long as I can sort the heating out in such a way that I don't have to have the overflow tank any more!
  19. Could probably just about fit a coke bottle on its side in the eaves at the front, that's about it 😂 (hence wanting to get rid of the tank from its current space, storage is seriously non-existent and the planned works to extend the dormer will mean even less as the only bit of eave that is bigger than a mouse hole will be gone)
  20. leaves me with a tank still though, looking for methods that don’t involve a tank but potentially retain boiler as-is if possible. interesting in the preheated though I’ll look at that, cheers
  21. I wasn't really sure where to post this, as I'm trying to build an overall picture of options and pretty much everything needs looking at, if I've posted it in the wrong place please do correct me, still quite new here. Overview: We're trying to purchase a small 3 bed chalet bungalow. I'm trying to get my head around what could / couldn't be done with it. At the moment it's badly laid out, has next to no storage spaces and at some point had a central heating system installed that I think was designed by a 2 yr old with crayons. Very recently a new Worcester boiler has been fitted, though. There is one real cupboard downstairs. It has the water tank plus a pump in it, that's that cupboard full. It's also in a really bad position and ideally the cupboard would come out completely and be moved. There is one usable "cupboard" upstairs in the eaves to one side of the dormer. That has the cold water tank / overflow tank in it... To make the place "useable" we would like to extend the dormer to enlarge the 3rd bed and install an en-suite to the main bedroom but that would leave no space at all to have a cold water tank / overflow tank. I'm looking at the sunamp thermino as that would fit in a space in the kitchen and remove the need for the cold water tank, plus allow for solar top up. What could I do about the overflow tank for the heating, though? What's the most compact solution for replacing that? The alternative to this would be replace the almost-brand-new boiler with a combi, but I've lived in three places with combi boilers and hated it every time - wife washing up, 14 yr old running hot taps full blast for no apparent reason meanwhile I'm stood turning blue in the shower and the heating has turned off for half hour because the boiler couldn't cope. When it comes to the heating system itself, the specification appears to have been "please place the largest possible radiators in the most inconvenient / useless location, preferably offset to ensure they line up with nothing at all". Half under a window, just off centre in the middle of the only usable wall, behind a door so you can't open it properly... So as they're all going to have to come out and be re-sited I was wondering about the alternatives, thinking maybe thermal skirting, but not finding a lot of positive feeback stories on those so far.
  22. I'm trying to visualise how yours was done, failing a bit lol. I don't think any of the internal walls on this place are load bearing, they don't appear to be. There is however *one* position beside the stairs, about 1m off centre of the ridge that I could run a steel down all the way from ridge to ground floor, will have to have a look and see if a foot could be put down there.
  23. Yes that's what I assumed, I'm just thinking about supporting the beam, without it being intrusive in the rooms below. My brother is doing a project at the moment and they've made him have 600mm pillars to put the beam on - last project I did it was 300mm required for a longer beam. Not sure if that's because something has changed regulation wise or just his SE being overly cautious!
  24. I'm looking at a potential project, a chalet bungalow. It's pretty small upstairs and whilst the front elevation has 2 dormers, the rear only has a single tiny dormer which seems daft, most others in the area have almost full width on the rear elevation. There is also room at the rear for a 1.5m extension for the full width. I've done plenty of builds / renovations before, none of them have ever been a chalet so this is a new one to me. I'd love any advice full stop on potential pitfalls and problems, plus advice on how it would be best to extend the joists so that the majority of the original rear wall could be removed. I would not want a dropped steel below the joists as the ceilings aren't exactly high in the first place. Also, I was thinking that it would be good to make better use of the existing eaves on the front elevation (which are inaccessible) by replacing the current wall with slide in storage between the posts. At the moment, the back of the existing wall is insulated so I'm thinking of putting insulation between the rafters instead - any pitfalls here to consider, or tips for best practice on doing that?
  25. One big advantage with an A-frame, foundation requirements are tiny - 3 parallel strips and you're done!
