I'm hoping to build a passive house next year. Planning application is due to be submitted in the next few weeks. I have a PHPP consultant in the mix working with the architect.
In the meantime I've been assessing energy requirements and on the basis that the cheapest energy is the one you don't use, I've spent some time in learning where it appears to be worth spending time, money and energy.
I started with Jeremy Harris' spreadsheet to understand the orders of magnitude of the heat losses. Many people have different ways of wanting to look at data and I'm no different, so I wanted to break the losses into discrete areas:
Walls
Windows
Doors
Roofs
Air via the MVHR
Air via infiltration (leakiness)
Jeremy's spreadsheet appeared to address air energy losses, but based on an ACH and MVHR efficiency. That doesn't seem right to me. I've modified the sheet (attached to this post) so it has 2 sources of air heat loss - one that uses 30m3/h per person and a heat recovery efficiency ratio (MVHR); and another that uses the air tightness ACH factor and no heat recovery (leakiness).
Using this approach suggests that the air leakiness losses are about equal to the sum of all losses from roof, walls, windows and doors. If my calcs are correct, it would make sense to focus even greater efforts on air tightness. I understand that Justine Bere's recent build had a blower test result of 0.15 - that makes a big difference to the heat loss - far more than speccing better windows, for example.
Does any of that make sense to you folk?
Kind regards
Mark
Drag files here to attach, or choose files...
Accepted file types: bmp, svg, jpg, jpeg, gif, tif, pdf, txt, png, odt, mp3, mp4, mov, qt, xls, xlsx, ods, doc, docx
Max total size: 5.86 MB
Uploaded Files
Heat loss calculator.xlsHeat loss calculator.xlsx
