Montipora
Everything posted by Montipora
  1. Hi @Onoff have you a link where you have seen this for £190? All my searches show over £300! thanks
  2. If you are within 1m of boundary you are allowed max 1m2 unprotected area i.e. Window including frame. If your window is larger then it would need to have 30 mins protection
  3. We had the self adhesive rods at our previous home where we had acrylic worktops. They worked well never came loose, but are stainless steel effect and marked quite easily.
  4. Drainage is into a branch connection that was put in before slab concreted
  5. Yes floor make up is as you say and with 2 layers of insulation so I think this is the way forward. Does it need to be 10mm? Or can you use the same method with 15mm. Thanks for your advice
  6. Thanks, that's what I thought would happen although we are installing a zip tap which does chilled water as well, so may not be such an issue
  7. Hi All, just about to fit insulation on top of concrete slab ready for UFH, but need to run a cold feed to the island for boiling water tap. Can this go under the insulation to avoid the UFH pipes, or just run parallel with them on top? Thanks
