Ralph
    7
Ralph last won the day on January 12 2023
Ralph had the most liked content!
Personal Information
  • Location
    Angus, Scotland
Ralph's Achievements
Regular Member
Regular Member (4/5)
337
  1. That round white thing seems to be a pressure switch but it's not connected. Presumably it detects a blockage and switches off the pump. I'm trying to remember exactly what RA Dalton said about having the pump going all the time but other than they found it gave better results I can't recall. I think they have it set up so there is effectively air going to the sludge return and the aeration at the same time.
  2. Thanks for this unfortunately I have the older discontinued control panel and can't find any manual online.
  3. Thanks that's good to know. I don't think the Bioficient has the moving parts, just the blower.
  4. Thanks Nick, I used to have RA Dalton service it but seemed a bit steep at £300+ a year to have someone basically change the pump filter and diaphragm. The first time they came out they put the blower on constant, they said they had found this gave the best performance. Do you think I could just fit an outside socket with a timer under the cover, plug the blower as a permanent fix? I don't really see what else the control panel is doing if it's on all the time anyway. I don't think it has alarms or anything.
  5. Hello, I could really use some help with my Klargester Bioficient 1. During a recent snowstorm the cover over the control panel blew off. When I went to refit it, I noticed that the air pump was not running. I’m not sure if this is related or just a coincidence, it may actually have been off for a few days before I noticed. The system has not tripped the consumer unit and power is still reaching the control box. However, the display is blank. If I press the reset button, the display briefly flashes the number “23” a few times, then goes blank again with just a small red dot showing at the bottom of the display. Things I have already checked: Fuses appear to be fine The unit is still receiving power I replaced the Secoh JDK 80 pump with another pump, but it still doesn’t run and the error remains I had a look in the chamber and there is nothing obvious like it's backed up or anything. Does anyone know what error code 23 indicates or have any suggestions on what else I should check? Also, how long can the system run without the blower before it starts causing problems with the treatment process? Any advice would be greatly appreciated.
  6. In my experience if you are an unsecured creditor in a liquidation you are getting nothing. We could not even get things like tiles left over as spares. In fact I had to resort to threats to get spare house keys back. I also tried to get information on warranties that were put in place by the contractor and got zero response. They only time I got any real communication from the liquidator was when they came after us for money.
  7. We used RIAS Scottish Conditions of Appointment of an Architect - Small Project Version ASP/2018 you'll find a copy online the English version will probably be the same. We went through the Schedule of Services and took a pick and mix approach to what was on on offer from the stages below. Although it was classed as a full service approach I would have said the architect took the lead for Stages 1 and 2 then it was over to the Architectural technician for the rest. There is a load of Additional Services that can be added to the below if required. We then agreed a fixed fee and off we went. This all really paid for itself when the builder went in breach of contract then tits up. Preparing the Design Work Stage 1.0 – Preparation of the Brief 1.1 Ascertain Client Requirements 1.2 Obtain Site information from Client 1.3 Advise Client of his/her duties under CDM regulations 1.4 Visit Site and carry out preliminary appraisal 1.5 Identify Project and Construction Budgets 1.6 Develop outline brief 1.7 Agree Preliminary timetable Work Stage 2.0 – Initial Design 2.1 Prepare initial design proposal 2.2 Provide indicative guidance on cost and timetable Work Stage 3.0 – To Planning Consent Application 3.1 Consult with Local Authorities and Utilities as required 3.2 Progress Stage 2.1 design 3.3 Prepare application for Planning Permission 3.4 Submit application for Planning permission 3.5 Advise on procurement methods 3.6 Report on timetable, agree revisions Work Stage 4.0 – To Building Warrant Application 4.1 Progress Stage 3.2 design 4.2 Co-ordinate work of other consultants 4.3 Report on timetable, agree revisions 4.4 Prepare Warrant Application 4.5 Submit Warrant Application Preparing the build Work Stage 5.0 – Construction Documentation 5.1 Advise on and agree form of Building Contract, including Contract Administrator 5.2 Prepare drawings, schedules and specifications sufficient for tender 5.3 Co-ordinate information from other consultants, specialist designers and contractors 5.4 Prepare Description of Work Work Stage 6.0 – Tender Administration 6.1 Compile list of Contractors, if applicable 6.2 Assemble tender documentation including Bills of Quantity or Schedules of Rates etc. prepared by others 6.3 Issue tenders to contractors for pricing 6.4 Take delivery of, and report on tenders 6.5 Advise on appointment of contractor 6.6 Agree frequency and scope of site inspections Progressing the build Work Stage 7.0 – Contract Administration 7.1 Administer the Contract 7.2 Attend Progress Meetings on site 7.3 Inspect the works as necessary to administer the Contract, review progress and quality in terms of the building contract 7.4 Issue instructions to the contractor for variations to the contract when approved by the client 7.5 Report on Stages 7.1, 7.2, 7.3 and 7.4 7.6 Advise client of when works are practically complete for handover Work Stage 8.0 – Post Completion Work 8.1 Advise Contractor of any defects 8.2 Administer the contract to final account
  8. Yup, pretty much the same thing happened to me a few years ago. They only actually got back in touch when they were trying to get money out of me.
  9. We're going to be hit with high wind and rain this week so mine will be staying on for a while yet. We get a good bit of solar gain. It looks like the heating has not come on for just over 24 hours and the main area is sitting at 23.8°C
  10. I think that is basically how most houses are built in Scotland these days. Like everything else there are advantages and disadvantages but the big difference is the reduced upfront cost.
  11. I'm really sorry to hear about this. I hope you manage to get something from the liquidator. Being afraid of this happening is one of the reasons we went for Scotframe, their payments were also in 4 or 5 stages.
  12. We are about 152m2 detached. We have quite an open plan house with vaulted ceilings and a lot of glass. We have been down to - 12°C this year. What seems to make a real difference is the wind. A brisk NNW coming off the Cairngorms really finds all those gaps. We also run the house quite warm, it never comes below 20°C and is quite often at 23°C.
  13. That does not seem bad. I'm about 10 kWh/day for everything else including DHW. I work from home so I'm not too bothered by it.
  14. Is that just for your heating? Still a bit too cold this far north to turn it off but we were down to 6 kWh/day last week on the heating as apposed to 14 kWh/day in January
  15. It's was definitely a journey and we still have stuff to do but it has been worth it. This forum has been a massive help and not just as a technical resource. No matter what's happened someone on here will have been through it. I know St Cyrus well, it's a cracking part of the world
