Ed_
Ed_'s Achievements
Regular Member
Regular Member (4/5)
36
  1. Thanks for the ideas. Not easy to get a suitable sprayer it turns out. Fortunately the part has gone on much better, for some reason yesterday's old roller (stored airtight) which doesn't roll so well anymore seemed to do the trick!
  2. I'm applying an external liquid applied membrane (bituminous) to the reinforced concrete walls of my new basement. Problem is, there are thousands of very small holes in the otherwise smooth surface finish, presumably tiny air bubbles a few mm across. When I apply the waterproofing, these holes do not fill, I hadn't noticed them before applying the waterproofing as they are very small. I've tried brushing and rolling and nothing will reliably fill them with the paint. What to do? AI suggests a tanking slurry. I am sceptical that this will fill these holes as they seem bigger inside than the part that breaks the surface. I don't really want to switch to a membrane as that seems a lot of work. I'm not too worried about the effectiveness of this layer. I have waterproof concrete which appears to be sound and carries a warranty, the basement is walkout so totally above ground on 2 of the 4 sides, and will have free draining backfill and a land drain, so it is unlikely to see a head of water ever. I'm really only applying the type A because I thought it would be easier to apply it than persuade a "waterproofing designer" that it wasn't required, even though BS8102 does allow just one system in my situation. But if i'm going to the trouble of applying it, it would be nice to do it properly. Can anyone suggest any ideas? It feels like a liquid applied type A is fundamentally unsuited to reinforced concrete, but I think it is very commonly used.
  3. It looked to me like they were running electrics under the false floor. Or maybe just put sockets on the internal walls?
  4. Have you read the Part O approved document? It is all in there. There is a simplified method and if you don't have much glazing then you may pass the simplified method, which you can do yourself easily in a spreadsheet. Worth checking first. If not, then you'll need to do a dynamic thermal modelling, mine was £660, I marginally failed the simplified test. You can use AC as a means of cooling the building, despite what right wing political commentators might have you believe:
  5. Read some examples of HSE prosecutions. Its a good idea anyway to get a feel for how things can go badly wrong, but you may also be shocked at the leniency. Trainee working alone killed - £30k fine for example. You have to have done something really bad to go to jail, act sensibly and you will not. I'd argue that things like CDM are a help because they give you a framework to work within and put obligations on the professionals, before CDM you probably didn't have too many options as a homeowner or self builder looking to ensure contractors worked safely (including not endangering you). One measure of whether you have the right attitude to safety is if you are willing to pay more for it. Safety costs and the client sets the tone for the site. If you employ the cheapest person who hasn't spent any time considering safety then you have some responsibility if it goes wrong. I had a basement contractor who didn't want to be PC, despite being the only contractor who would be onsite at that time and taking over from a bare site. I felt I could have done the PC role, and probably better than this contractor given their apparent attitude, but could I defend myself if anything went wrong and I, an amateur, was controlling the site part time rather than the experienced professional doing the work? Clearly it wouldn't have been right and their refusal to take a responsibility that was clearly theirs ruled them out.
  6. I think there are two big issues with the "stuff": 1- it disproportionately affects lower budget builds. 2- it mostly has to be paid out early, sometimes years before even starting the build, this can be challenging financially. A lot of this is ripe for disruption but I fear the self build market is too small to make the development costs worthwhile. @Gus Potterhas written persuasively in other threads about the savings from getting a good designer/engineer in early. It seems to me the issue is that obviously makes that professional more expensive, and how does a self builder separate someone who is offering a better service from someone who is just charging more? There is no way of knowing whether a professional has settled for the first option they found or considered 10. This is why I try to do as much as possible myself, I'd rather die by my own mistakes, at least I will have learnt something!
  7. I'd say confidence is a big issue, most self builders are doing it for the first time and spending their life savings. This leads you to stick to what is known/common which is very often what is used by volume builders. One advantage of self building should be to build bespoke to the situation and to use innovative ideas that haven't reached or aren't suitable for the volume builders; leveraging the experience of others (e.g. this forum) is crucial. Another thing I have found is that you have to try and understand everything yourself. Any professional you employ, no matter how good, has a different set of incentives (being paid, maximising profit, reducing their risk) which are different to your own, you need to try to be an intelligent customer. Easier said than done. I'm still amazed that no one has invented a better way to finish an internal wall than to throw wet muck at it and smooth it over! Probably they have but big plaster has shut them down.
  8. With the prodigious amount of rain in January the water level in my test hole ended up about where the top of the soakaway would be, for about a month. Not promising. I was resigned to attenuation and discharge to the sewer, but the costs of doing the tank and the connection to the sewer are at least £30k, so thinking again about options. Has anyone designed a swale or rain garden? I have a garden 12.5 x 25m, gentle slope (0.5m) away from house. Wondering about running a french drain towards the end of the garden and then making a depression there to hold whatever doesn't soak in by the time it gets there. I'm not really concerned if I get a lake in winter. Where I'm a bit stuck is how to design it. I've looked at the suds manual CURIA 793 but it's 800 pages and not really aimed at single houses. If I just size my depression to the 1 in 100 year rainfall with 40% for climate change then is that going to satisfy a BCO?
  9. Well I certainly hope I'm right!
  10. I just want to do the minimum of box ticking, if it is required. I'm certainly not going to sit on hold to them for ages, I don't need it, but do they?
  11. I'm finding some references to needing to submit a commencement notice to the LPA when I commence my build, but for my LPA (surrey) I can't find any suggestion it is needed or how I should do it. There is no CIL here. Do I need to submit a notice? Shall I just email them?
  12. The thing with thermal bridge calculations is a high psi just tells you that the bridge is much worse than the surrounding structure at keeping the heat in. This means that if your house is otherwise very well insulated then you will get a higher psi. If you decide to mitigate your thermal bridge by increasing insualtion adjacent to it, you increase the psi - counterintuitive. A high psi is (imo) not an issue provided that the building taken as a whole is sufficiently insulated and your thermal bridges are good enough to prevent condensation and mould, so the lowest internal temperature at the bridge is more illuminating.
  13. Not nonsense - £104 billion from 2010 to 2023 - https://journals.uclpress.co.uk/ucloe/article/id/3584/ The fact that bills continue to go up is obscuring the fact that renewables have mitigated that rise. Its not immediately obvious, but a very simple and obvious concept when you first see it: Renewables displace other generation (obviously). That other generation would have been more expensive than the generation that wasn't displaced (again, obviously) So we just need to net off the "subsidy" of those renewables against the expensive generation they displaced £104 billion saved QED.
  14. Every windfarm is cleared (or not) by MOD. Much overstated, see any research on the topic. Not specific to wind. They are going regardless. North sea is a declining basin and fewer fields are cost competitive. Oil can be sold regardless of whether it is used in the UK - see Norway! Blade factories in Hull & IoW. Vestas Nacelle factory coming to Scotland Monopile fabrication facility on Teeside JDR Cables at Hartlepool, multiple Prysmian cable factories We probably make as much of wind farms as we do oil and gas facilities. Piper alpha?
  15. Presumably their house was cheaper on account of the proximity to noisy kids?
