How to Conceal a Door in a Wall
Ferdinand
I spotted this inside a local cafe this week.
Liquorice Allsort chic is not quite my taste, but the door is not as obvious as could be the case.
It is an a sample of how to incorporate an element into a stronger pattern than the outline as a means to de-emphasise it. Here it could have been further concealed by choosing a different handle, or concealed hinges.
It could also have been made full height.
  • Like 1
3 Comments
Recommended Comments
I like the idea of a hidden door but like you it’s not to my taste...... but admittedly I did build my own hidden door very like this........ it’s in my shed and I use it to store long stuff under the eves.
  • Like 2
We're doing similar with 30mm strips of birch ply, full height over our flush door openings. Router out a handhold along one edge of a strip, so no visible handles and roller catches. Hopefully it will look the dogs - took a lot of head scratching between the architect, joiner and ourselves before we worked out the detail.
  • Like 1
