  • entries
    21
  • comments
    159
  • views
    69603
About this blog
Pete and Mandy's Highlands Build
Entries in this blog
ICF walls and dodging bullets.
Day 48 of the build was a big one, we poured the ICF ( PolySteel) walls.   Following the slab pour 2 weeks earlier, we start on building the PolySteel ICF walls. I've no experience with ICF, and thus can only comment on the usability and quality of PolySteel. The process is straightforward, all the blocks are t&g on all edges, so you simply use a bead of fire rated foam and push the blocks together. Each block clips to the last with two **clips joining the metal mesh inside th
Jenki
Jenki in ICF WALLS
