Moonshine Posted May 23, 2019 Posted May 23, 2019 (edited) Just checking I am right in my understanding of the CIL rules for applying for exception. If I submit a planning application now without CIL exception, I can apply for CIL exception at a later date, as long as it's approved prior to commencement of works? Cheers Edit: CIL form 7 seems to confirm this as the case Edited May 24, 2019 by Moonshine
PeterW Posted May 24, 2019 Posted May 24, 2019 You can’t apply for exemption before permission. Council will calculate the liability as part of the application approval. You then accept liability, then complete the self build exemption form before starting any work and then when you finish you send off your completion statement and docs within the timeframe. 1
Moonshine Posted May 24, 2019 Author Posted May 24, 2019 1 hour ago, PeterW said: You then accept liability, then complete the self build exemption form before starting any work and then when you finish you send off your completion statement and docs within the timeframe. Thanks, i know there are a few bear traps with CIL, and i want to make sure that i am going in with my eyes as open as they can be.
