Underground serve separation
11 hours ago, Onoff said:
Check the sites for your electricity/gas/water and they'll likely have something like this:
https://www.thameswater.co.uk/tw/common/downloads/your-business-developer-services/new-water-supply-regulations-guidance-notes.pdf
I Googled "water trench depth other services".
Some of it is a bit incomplete though, which is the problem - this is from United Utilities:
Trenches: These should be lined with sand or selected soft earth, not rubble. They should also be wide enough for the pipework. Please keep a minimum distance of 350mm away from other services such as gas, electricity and at least 1m away from trees, lamposts and lighting columns
No mention of BT for example, so it's open to interpretation
1 minute ago, Onoff said:
BANG ON!!! Thank you. That is exactly what I was looking for!!!
