worldwidewebs Posted September 6, 2016 Posted September 6, 2016 I'm sure there was a resource somewhere that stated how far apart and to what depth each of the utility companies' pipes/ducts must go. Does anyone know where it is?
Tennentslager Posted September 6, 2016 Posted September 6, 2016 Any good? https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.njug.org.uk/wp-content/uploads/V1-Positioning-Colour-Coding-Issue-8.pdf&ved=0ahUKEwjFwrfUmfrOAhXWFsAKHfC6BRQQFggkMAI&usg=AFQjCNFhzY5fDIDEo-f-Sz3OF0NYGinxqg&sig2=z_13syNdkUh07MYp1niIug 1
Onoff Posted September 6, 2016 Posted September 6, 2016 Check the sites for your electricity/gas/water and they'll likely have something like this: https://www.thameswater.co.uk/tw/common/downloads/your-business-developer-services/new-water-supply-regulations-guidance-notes.pdf I Googled "water trench depth other services".
worldwidewebs Posted September 6, 2016 Author Posted September 6, 2016 11 hours ago, Onoff said: Check the sites for your electricity/gas/water and they'll likely have something like this: https://www.thameswater.co.uk/tw/common/downloads/your-business-developer-services/new-water-supply-regulations-guidance-notes.pdf I Googled "water trench depth other services". Some of it is a bit incomplete though, which is the problem - this is from United Utilities: Trenches: These should be lined with sand or selected soft earth, not rubble. They should also be wide enough for the pipework. Please keep a minimum distance of 350mm away from other services such as gas, electricity and at least 1m away from trees, lamposts and lighting columns No mention of BT for example, so it's open to interpretation
worldwidewebs Posted September 6, 2016 Author Posted September 6, 2016 11 hours ago, Tennentslager said: Any good? https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.njug.org.uk/wp-content/uploads/V1-Positioning-Colour-Coding-Issue-8.pdf&ved=0ahUKEwjFwrfUmfrOAhXWFsAKHfC6BRQQFggkMAI&usg=AFQjCNFhzY5fDIDEo-f-Sz3OF0NYGinxqg&sig2=z_13syNdkUh07MYp1niIug At least as a starting point, cheers!
Onoff Posted September 6, 2016 Posted September 6, 2016 United Utilities seen to be singing from the same hymn sheet as Tennants posted up if you look here: https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.unitedutilities.com/documents/Excavation_option_agreement.pdf&ved=0ahUKEwip4rXdtPvOAhWoL8AKHb7mBZAQFgggMAE&usg=AFQjCNHGRa0zwOSRAdOzH8UAH1V4LB3A-A 1
worldwidewebs Posted September 6, 2016 Author Posted September 6, 2016 1 minute ago, Onoff said: United Utilities seen to be singing from the same hymn sheet as Tennants posted up if you look here: https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.unitedutilities.com/documents/Excavation_option_agreement.pdf&ved=0ahUKEwip4rXdtPvOAhWoL8AKHb7mBZAQFgggMAE&usg=AFQjCNHGRa0zwOSRAdOzH8UAH1V4LB3A-A BANG ON!!! Thank you. That is exactly what I was looking for!!!
