ultramods Posted April 12, 2019 Posted April 12, 2019 (edited) Last year I asked about how best to create a DIY large sliding door, 3300mm wide by 2650mm high, the consensus was the best approach was a stud.carcass timber frame covered by 6mm ply or MDF. This is what I was planning to do. However I had a cabinet maker in the house to quote for making the stair treads and he noticed the runner in place for the large door and asked when I was planning. When I told him, he said he would not use normal softwood timber for the carcass as it will warp over time. Instead he recommended cutting up a sheet(s) of birch ply length ways into battens and then gluing them together to make the carcassing timber. However I forgot ask him to specifics. Can anyone recommend what thickness I should go for 2 x 12mm or 2 x 18mm ply. What depth should I make the ply battens, I am thinking 38mm (the door needs to be around 50mm, including the 6mm covering sheets) Is it ok to glue all the strips of ply lengthways in the same direction/orientation? Do I need to use birch ply or would any hardwood ply be ok, since it will be covered by a sheet of ply or mdf What intervals should I have for the horizontal and vertical ply battens that make up the door, how about 660mm? Edited April 12, 2019 by ultramods
ultramods Posted May 9, 2019 Author Posted May 9, 2019 I am going to start making the door this weekend. For the structure I have 18mm x 40mm x 2400mm strips of birch ply. Can any one suggest the best way to fix the strips together to increase the vertical and horizontal strength. I can't decide if a T, I or 4 pieces would be best, in terms of strength, weight and actually assembling it. Also what is the best way to fix the strips together, glue with screws or use a framing nail gun or finishing nail gun. Also would I need to clamp the wood whilst the glue sets even if it's also screwed or nailed?
PeterW Posted May 9, 2019 Posted May 9, 2019 I love this stuff for quick and simple joints that are incredibly strong. Pin it every 150mm with finishing gun.
ultramods Posted May 9, 2019 Author Posted May 9, 2019 On 09/05/2019 at 19:33, PeterW said: I love this stuff for quick and simple joints that are incredibly strong. Pin it every 150mm with finishing gun. Expand Thanks I will give it a try.
ultramods Posted May 19, 2019 Author Posted May 19, 2019 Feeling pretty pleased with myself as I have been dreading making this door. video-1558292016.mp4Fetching info... 7 1
PeterW Posted May 19, 2019 Posted May 19, 2019 That is superb ..!! Got any close up photos of the construction ..? And what track system have you used ..?
ultramods Posted May 19, 2019 Author Posted May 19, 2019 (edited) On 19/05/2019 at 21:46, PeterW said: That is superb ..!! Got any close up photos of the construction ..? And what track system have you used ..? Expand It's the Coburn Straightaway 180 https://www.coburn.co.uk/product/straightaway-180/ I will do a blog post next week once the door is complete with lots of photos Edited May 19, 2019 by ultramods
