Hey
I can’t seem to get this back on the track
presume I need to remove it to get the bottom one on then the top .
No obvious screws or adjustments- don’t want to use brute force !!
Ok
Answer my own question
I’m assuming the little silver plastic covers aren’t meant to be stuck on - bleeding builder .
Anyway forced them off and found a screw underneath to adjust !
You normally push down on the wheels and they move up and down so you can position them in the groove, let them go and the wheels move back into the resting position and they lock in place. The bottom ones move up and the top ones move down,simples!!
Yeah this is what I initially thought .
zero movement from wheels up or down .
That ‘hidden’ screw moves them up and down - then it was simples ?
Ok, will look out for the screw next time!
