Does any one know where i could get 90 degree verge caps for a slate tiled roof, 90 degree 450mm ridge slates with scot verge hdv9 verge covers. Having trouble finding any to cover the ends and want to ensure the roof is fully protected from bats / birds as the roof is 7 metres high and 10metres high at the other end due to fall away, hence want to make sure its fully sealed before the scaffold comes down.
Some has suggested using slate tiles and cut them to fit and fill the cap area between scot verge and ridge slates - anyone done this before?
Any help / suggestions welcomed.
Make them out of ali or lead or buy fibreglass verge trims?
also you could oversail slates by 50mm and nail fix slates to the verge, poly sulphide pointing where they join.
cheers tony been playing about today and think i'm going to adapt using a slate fixed to the end as you have suggested.
