If designing in a balcony from first floor lounge that spans the length of the house approx 12m
What would be the optimum method to prevent cold bridges.
1) external hung style
2) inboard so as it sits inside the dimensions of the house.
It would be 1.5 depth.
Is this a side or gable end balcony as it makes a difference when it comes to the structure if you want the roof to cover it.
It would be a side balcony. Probably no gable end as such due to a mono pitched roof. I have seen quite a few kit style home with an "internal" balcony area that is sheltered from the elements from all sides. Drainage, thermal issues can obviously be countered.
Seriously consider stepping the ground level in too as what then happens is the balcony acts as a brise soleil for the lower windows.
