The fan has stopped - about 12 years' old so time to go to fan  recycling heaven/wherever. Only issue is that there is no obvious way to remove the outer cover! No screws, no obvious leverage points, even tried a very hard pull with a pipe wrench and not coming off. Before I start battering it and messing up the WC ceiling - does anyone recognise this and have a suggestion for removal technique???
Thanks
Vent axia solo plus. Been subject to loads of redesigns over the years. Still available. Can't remember how to get the cover off though.
OK so there are 2 push release catches inside after pulling out filter. I found this after forcing the cover off ? At least the other one I need to replace will be easier
