Our_Valleys_build Posted January 17, 2019 Posted January 17, 2019 (edited) hi im looking for images that people may have or info on the bradstone keinton in masonry block type and in t form, these people seem to be hard work trying to track down samples and what actual types your looking at. Anyone ever used this stuff before? Any areas i should look out for when thinking of using this stuff. My thoughts were to combine the stone work with forticrete heads and sills along with flat finish coins Thanks Edited January 17, 2019 by Our_Valleys_build
Declan52 Posted January 17, 2019 Posted January 17, 2019 It's the motar mix which is the important bit. You have to make sure whoever is doing it measures out each mix so you get no colour variations in the motar. As far as building them goes they are treated like normal blocks. You will just have to set the line to suit the size or sizes of the block you pick. Will it be a natural stone version or a reconstituted block???
Our_Valleys_build Posted January 18, 2019 Author Posted January 18, 2019 okay our brickie is top notch he's old school so no doubt he'll get it spot on. i believe a reconsituted version possibly as there cast from croncrete to give them the natural stone look
