Hi All,
I am struggling to find some 32mm bore closed cell insulation for my MDPE water pipe to put in the duct where it passes through the floor, anyone got any suggestions?   I can only find 35mm bore - would that be ok? or would the air gap between the insulation and the pipe be a problem?
I was thinking of cutting discs from 100mm PIR board to fill the duct with a 32mm hole in the centre.
Thanks, Wozza.
