Dee J Posted January 3, 2019 Posted January 3, 2019 Pondering the feasibility of a cost-conscious conversion of a workshop building to residential, and one of the key points would be if we could retain the existing roofing. So its a fairly conventional pitched roof with timber A-frames and purlins covered in cement fibre corrugated sheets. It was re-sheeted recently enough for it not to be asbestos. Currently its insulated in about 75mm of kingspan and clad in 9mm ply.... ok for a workshop, but insufficient for residential. Also we'd need to integrate some proper insulated skylights to replace some sections of transparent sheeting. Any advice? Thanks.
scottishjohn Posted January 3, 2019 Posted January 3, 2019 first stop is building control regs to see what is minimum insulation value on roof and walls ,and is there a dpc in floor+ walls of the building any conversion you make will have to comply with CURRENT requirements for a habitable dwelling -as it is a change of use ,you may even find that the roof structure will not pass for a dwelling if it was an agricultural building to start with . 1
