Pocster Posted December 13, 2018 Posted December 13, 2018 Hey all So got these pull cord curtain rails ( hate things like this ) . One of the slider bits that the curtain hooks to is broke . Its the one beyond the bit of plastic in the rail that drags everything else to open and close . So I need a new slidey bit ( technical term ! ) . Can’t see any way though you get that bit out though to remove broken bits and replace . Forgive useless description!!!
Pocster Posted December 13, 2018 Author Posted December 13, 2018 Managed to get one of these bloody things out !!
AliG Posted December 13, 2018 Posted December 13, 2018 It is a curtain rail glider, can't see the exact same one, but a similar one may work https://www.google.com/search?q=curtain+rail+gliders&client=safari&rls=en&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjH8cDCqZ3fAhXkUBUIHX-OAvkQ_AUIDygC&biw=1280&bih=714
Pocster Posted December 13, 2018 Author Posted December 13, 2018 45 minutes ago, AliG said: It is a curtain rail glider, can't see the exact same one, but a similar one may work https://www.google.com/search?q=curtain+rail+gliders&client=safari&rls=en&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjH8cDCqZ3fAhXkUBUIHX-OAvkQ_AUIDygC&biw=1280&bih=714 Cheers ! Will explore !
