epsilonGreedy Posted December 11, 2018 Posted December 11, 2018 I need to route some MDPE water pipe around the outside of my footing trenches to the static caravan. Given the cold weather can someone suggest a reasonable bend radius at a 90 degree corner? The current air gap between footing blockwork and mud trench wall is 120mm.
Onoff Posted December 11, 2018 Posted December 11, 2018 4 minutes ago, epsilonGreedy said: I need to route some MDPE water pipe around the outside of my footing trenches to the static caravan. Given the cold weather can someone suggest a reasonable bend radius at a 90 degree corner? The current air gap between footing blockwork and mud trench wall is 120mm. 15x the diameter increasing to 25x in very cold weather. 1
epsilonGreedy Posted December 11, 2018 Author Posted December 11, 2018 1 hour ago, Onoff said: 15x the diameter increasing to 25x in very cold weather. That is consistent with the radius of the delivered coil, thanks for the guidance. As delivered the 50m coil diameter was 900mm = 450 bend radius = 18x pipe diameter. In the end I used a 2m section to test the tightest bends through the foundation trenches, it was simpler to route the pipe than the maths indicates.
