Hi,
I've two different wall build up options and conflicting advice about which is more cost effective. The first is a twin stud, cellulose fill, with aquapanel & k-rend. The second is Climawool / timber frame / outer block leaf which is slightly thinner and claimed to be cheaper. Now, I know that's light on detail but any thoughts about cost: I would assume blockwork will take longer / need scaffolding longer vs aquapanel / k-rend cost so it's about even. Thanks.
You will find that the k rend is more expensive on aqua panel
You will need a base coat and mesh
If you are using a concrete block Not a high suction block You won’t need a base coat or mesh
