Has anybody used timber bracing only for the likes of quadlock/logix/nudura?
I'm considering using timber batons on the inside of the walls to form a service void and to fit plasterboard to, rather than directly to the ICF surface. If these strips are added before the pouring stages, would that be sufficient for vertical bracing? I understand I'd still need to deal with lateral movement at the base and top.
And for the outside, I'm adding 100mm EPS sheets to ge tto passive levels - glued and screwed in to place. Would they also provide enough support/rigidity?
