Alexphd1 Posted September 1, 2018 Posted September 1, 2018 Anybody with experience who has drilled multiple holes in a mirror. Trying to create one of those make up mirrors.
MikeSharp01 Posted September 1, 2018 Posted September 1, 2018 (edited) Mirrors are just glass so you need glass drill bits like These (which I gave used on many occasions) just don't have the hammer action turned on! For bigger holes there are these which come in a variety of sizes they need a guide to hold them in place (I have a set I got from Lidl which work fine on tiles have not tried them on glass.) and they are usually run wet. Edited September 1, 2018 by MikeSharp01
Jeremy Harris Posted September 1, 2018 Posted September 1, 2018 Best tip I heard was to immerse the bit of glass/mirror in a shallow tray of water. Apaprently the water damps down the vibrations that lead to stress cracks and makes drilling glass really easy. I drilled a hole in the centre of a thin (2mm) bit of glass a few years ago by immersing it in a bowl of water (sat on a weighted down block of wood) with a Dremel and a diamond bit. Worked a treat and I was then able to screw the glass to a mandrel with a fibre washer (stopped it spinning with some superglue - easy to get off with acetone and then scrape the residue off with a Stanley knife blade), chuck it in the lathe and use the Dremel to grind it into a disc (long story, but I was repairing an old instrument that had a broken glass face and had a hole in it for the needle zero mechanism to fit through).
