jbrwilkinson Posted June 13, 2018 Posted June 13, 2018 Can anyone recommend a funky wired door chime that we can configure with our Loxone home automation system? We'd prefer wired as the sheer amount of steel in the house means WiFi is a bit sketchy...
Temp Posted June 13, 2018 Posted June 13, 2018 Google found this.. https://www.loxone.com/enen/kb/door-controller/ which suggests it's possible to use an IP camera to see who's at the door in the loxone app. Also mentions a loxone intercom so presumably you can speak to them etc. Perhaps there is a combined door button/camera/intercom thing that would be suitable? Scroll down that page for list of links. I've not looked at these. Presumably there is also a loxone forum and I would post there if you haven't already done that.
jack Posted June 13, 2018 Posted June 13, 2018 29 minutes ago, Temp said: Google found this.. https://www.loxone.com/enen/kb/door-controller/ It's a decent system apparently, but eye-wateringly expensive (all the Loxone branded stuff is, imo). One Loxone dealer in Belgium has a solution that integrates Doorbird intercoms with Loxone, if that's what you're after. You can set up a wired doorbell system using one digital input monitoring a button of your choice, and using one of the outputs to trigger any wired system. When you say "funky", do you mean in terms of tones it plays or how it looks (or both)? Edited to add: I'm on the Google Groups Loxone mailing list. Some very helpful people contribute to it.
