epsilonGreedy Posted May 17, 2018 Posted May 17, 2018 The House Builder's Bible warns about the shady world of independent "brick factors" with their undisclosed referral commissions. I wonder if these online brick library outfits are just 21st century brick factor wolves in HTML clothing?
PeterW Posted May 17, 2018 Posted May 17, 2018 It has been discussed before - brick factoring happens a lot and they now trawl the planning portals looking for where a spec has been approved and one of their products may well match. Your best bet is make friends with your local BM and let them know what you are doing - you’re about to spend upwards of £50-70k on materials that they could see a good chunk of. Price is only one factor in the mix - service and delivery need to be up there too as getting that last “extra” drop on a Friday so your trades can start at 8am Monday can be worth the extra 1% discount you managed to get buying online ....
epsilonGreedy Posted May 17, 2018 Author Posted May 17, 2018 1 hour ago, PeterW said: Your best bet is make friends with your local BM and let them know what you are doing - you’re about to spend upwards of £50-70k on materials that they could see a good chunk of. Price is only one factor in the mix - service and delivery need to be up there too as getting that last “extra” drop on a Friday so your trades can start at 8am Monday can be worth the extra 1% discount you managed to get buying online .... My motivation is not to shave 1% of the brick order invoice by dealing online. Instead I am looking to save 20 to 50% by locating a substitute machine made brick that still creates the required conservation visual impact. I have found some good examples at BrickHunter however before becoming a named lead via such a site I wanted to understand the business model they use. https://library.brickhunter.com/wienerberger-marziale-65mm-machine-made-stock-buff-light-texture-clay-brick https://library.brickhunter.com/bea-clay-products-sexton-sulphur-66mm-waterstruck-slop-mould-yellow-light-texture-clay-brick https://library.brickhunter.com/wienerberger-smeed-dean-bermondsey-yellow-rustica-65mm-machine-made-stock-buff-light-texture-clay-brick
PeterW Posted May 17, 2018 Posted May 17, 2018 From the links you know the supplier and name so just go ask your local BM for a price ..?? Alternatively try someone like Huws Gray online and get pricing through them - full loads of mixed inc blocks always get decent prices 1
