Onoff Posted April 5, 2018 Posted April 5, 2018 So back around March 2015 I posted up on eBuild about doing a few bits to keep my 1998 Warmflow oil boiler going. I fitted a new burner nozzle, a couple of new baffles and re-made the 2 piece, rivetted together lid. 2015 I didn't treat the steel other than rubbing it down and spraying with high temperature black paint. I also replaced the burnt thru insulation mat under the lid. Fast forward to now, Apr 2018 and I decided to take the new lid off to give it a quick respray as SWMBO had placed a rusty garden ornament on to and scuffed it all. Underneath was shocking, the lid has a 1mm tin cover and a heavier 2mm thick formed tray. The tray section was as rusty as! It was WORSE than in this picture which is after I wire brushed it: 2018 The rust from the lid caked this insulation but I forgot to take a photo before I vacuumed it: Underside the lid insulation is a bit black: For now it just got the worst off the rust brushed /scraped off and that atop the insulation hoovered up. Gave the inside a quick spray again: The original lid lasted far longer. What causes this rust, condensation? Cheers
Onoff Posted April 5, 2018 Author Posted April 5, 2018 16 minutes ago, dpmiller said: Yup. Was the lid well clamped down? Well I thought so, two wing nuts.
