Trying to find a drawing of dpc window detail, just to check what I'm doing is right,  also I have a 50mm cavity so has going to use 38x38 treated timber or should I be using insulated cavity closer then strapping windows inside
John
I strapped ours, seems pretty rigid.  Insulated cavity closures fitted.  Window frame taped to the reveals.
