3 hours ago3 hr It's time to tank.But I only have a small section to do sealing the joins here. There's no harm in just tanking over the entire of this is there, may as well use up the solution otherwise it would just go in the bin?
2 hours ago2 hr As an aside, with my tanking kit the instructions said first coat vertical, second horizontal, third vertical. As in brush / roller lines vertical on the 3rd coat for water to run down. Belt 'n braces.
1 hour ago1 hr Author Makes sense I suppose. I haven't opened my tanking kit but I'll remember this for when I get to the job and do just that.
1 hour ago1 hr 1 hour ago, Onoff said:As an aside, with my tanking kit the instructions said first coat vertical, second horizontal, third vertical. As in brush / roller lines vertical on the 3rd coat for water to run down. Belt 'n braces.Ffs. Water will not defy gravity because the direction of the brush stroke define these laws.“Springers final thoughts……”Water cannot run down these ‘lines’ as they will be smothered in feckin tile adhesive.End transmission. 🤦♂️😌
45 minutes ago45 min 3 minutes ago, Mr Punter said:I like the extract vent.These are the way forward. “Repent, all yea heathen, utilitarian ruffians, and accept’th not the petrol station toilet type units provided by the cheap-seat-lovers”.Do not spend 7 figures making your dream home, and fit anything less.
Just now1 min Author 50 minutes ago, Mr Punter said:I like the extract vent.Canny bit of graft went into that vent.
