26 minutes ago26 min Hi all, when my self-build neared completion about four years ago, the internal doors has all been hung by the carpenters. They all opened and shut and locked perfectly - as you'd expect. However, the decorators then removed them all to paint the frames and remounted them. While most of them are OK, a number now have 'issues'. The first being that in removing and refitting the screws on the hinges, they have trashed the heads. Admittedly, the screws were supplied with the hinges and weren't great quality.More importantly, some of the door are now misaligned in that the latches and, where fitted, the locks no longer align so the doors won't close/lock and in a couple of cases have started to scrape slightly on the laminate flooring. I've also noticed a creaking/cracking sound on the doors at the point they are closed or just opened, which oiling the hinges doesn't address.I've enclosed a photo, though it's not very obvious, but it shows a lock on the door seems to have dropped 2-3mm and no longer engages. On the door in question, the hinges look fine (i.e. flush to the frame - not proud or recessed) and the gap between the door and frame looks consistent.The first thing I need to do is replace all of the cheap screws that were used (any suggestion on decent screws very welcome!), but I'm wondering if the carpenters had used packers behind the hinges on the frame which maybe the decorators discarded or mixed up.Any ideas or suggestions?
Just now1 min Have they definitely put the right doors back in the right holes? If so then your theory sounds most likely. However were they working perfectly prior to decoration or has the building settled since being built? It seems a lot of work needs to be done by some hinge pads to rectify all the problems you have. I find the doors and frames settle the most in first few years or even months, then once adjusted tend to stay fine.
