6 hours ago6 hr Not some fashion thing regarding sandals, but...Should I use a sock on a French drain perf pipe in heavy clay?On one hand, it should keep some of the clay silt out of the pipe. On the other, it'll probably block the fabric up, no?
1 hour ago1 hr 5 hours ago, Alan Ambrose said:On one hand, it should keep some of the clay silt out of the pipe. On the other, it'll probably block the fabric up, no?Aren't you better off putting the filter material down first, then gravel/loose fill, then pipe, more gravel and then wrap the filter material round?
25 minutes ago25 min 25 minutes ago, Alan Ambrose said:I think I'm going to go without socks / membrane.Commando!
Just now1 min +1 for Ricks method. Lay membrane in trench bottom and up sides gravel in bottom, land drain pipe, more gravel fold membrane back in and back fill. Gives a much bigger surface area to pull water.
