5 hours ago5 hr Wonder if anyone has any advice on what to do.Old gravity system that ran fine for years but last year repeated problems with boiler not managing to fire continuously.Some pipe work removed and changed over to pressurised system. All seemed well, heating and water working.When heating is called for this year not working again - lots of air in the system so bled the rads and re pressurised and heating working again.Now the hot water pipes are making a lot of noise when you run any hot tap, a lot! They always used to make a little bit of noise but nothing like now.Is it likely more air trapped in the system? If so can’t really see how to get it out if I have already bled all rads and tried opening valves above boiler and the hot water cylinder.When I re pressurised the system I set it to the max pressure.And how can one find the cause of the the loss of pressure over the summer?Cheers
2 hours ago2 hr Author 24 minutes ago, -rick- said:What do you mean by max pressure?There are two dials on the pressure gauge. The actual pressure (which was very low before I refilled) and the other dial (which doesn’t move?) which I presume to be the upper pressure limit. I filled up to that.
2 hours ago2 hr What's the number on the dial?Pressure should be a bit over 1 when the system is cool, will go up when warm. Anything over 2bar is too high.
1 hour ago1 hr I should add that the pressure on the sealed system is a different issue to problems with your hot water pipes or losing pressure generally. But having the pressure too high is dangerous so should be addressed first.Guess for the hot water issue is that maybe your expansion vessel has failed/lost pressure. (White tank attached to water supply to HW tank)
1 hour ago1 hr Author 1 hour ago, -rick- said:What's the number on the dial?Not sure but up there tomorrow so will check.Can’t imagine the expansion vessel has failed as only went in around march
1 hour ago1 hr I'm not an expert here so maybe best to wait for others.Air should not be getting into the system full stop. The pipework to the taps should be entirely separate from the pipework that heats the house and the hot water. So a problem on one side should not affect the other.Maybe photo(s) of the cylinder, boiler and all the nearby plumbing would be useful.
1 minute ago1 min 57 minutes ago, -rick- said:The pipework to the taps should be entirely separate from the pipework that heats the house and the hot water.Exactly.So if jfb has changed over to a mains water supply pressurised system, he should be able to tell us the actual mains pressure of the supply, that he has a pressure reducing valve installed and what it is set to.The pressure in the heating system to the rads etc will be completely different and about 1 bar or thereabouts.The pressure in the hot/cold water system will be lower than mains - possible 3 bar or thereabouts but depends what his mains pressure is and what his reducing valve is set to.Pipes can make noise from trapped air - typically a knocking type sound, and possibly sudden spluttering from tap outlets. Pipes can make noise from thermal expansion and rubbing against joists and floorboards when they heat up and expand from running hot water through them - this is more like squeeking and creaking noises from under the floor when the heating system comes on.From jfb's words he doesn't sound like a plumber (nor am I) - so why is he repressurising the system and opening and closing valves himself ?Boilers can have an air purge process they go through - what boiler do you have and is it displaying any messages or error codes etc ? Edited just now1 min by Spinny
