1 hour ago1 hr Hi folksWe have a conundrum with the Completion drains test for our private drainage with a pumped discharge. The house is finished, lived in and the drains have been used for around three months. Before we started using the drainage system we did a test by bunging the system just before the private drainage filling with tap water to test and then using an emersion pump to pump the clean water into a field drain. Now that the drains are used it will be more difficult to deal with the water in the drains after the test. If I remove the bung the private drainage will become overwhelmed. If I remove the central cap on the bung it will discharge slower, and the pump will be able to cope, but the quality of the discharge water would be questionable. I could use a septic tank emptying service, but, if possible, I would like to avoid the cost. Any ideas, what have you guys done?
Just now1 min Do the test then pump out the last chamber onto the flower bed. I’m not seeing the problem really.
