November 4Nov 4 34 minutes ago, jimseng said:Can you expand a bit more on the "select fan coils as heat mode" bit.Can you expand a bit more on the "select fan coils as heat mode" bit. I can accept a min 25 degrees flow temp but getting even a couple of degrees cooling in the summer is worth it for me, given I will be throwing away solar energy otherwise.Grant have cooling hidden from view depending on the heating type. The default is radiators and only heating is exposed. If you select fan coils and maybe UFH then cooling becomes exposed apparently.If in heating mode you will get zero cooling, no matter what your selected flow temperature.20 minutes ago, marshian said:that 100% Correct? I get that the BUS Grant is to incentivise movement away from fossil fuels but chosing to heat HW by direct rather than using a heat pump is an option that allows a reduction in the size of the heat pump to closer align to the Ch needs and a simplification of the circuitryThe grant says specifically that house and DHW shall be heated by the heat pump
