October 21Oct 21 Hi All.I am looking to have a heat pump and 250l cylinder installed in Somerset. I have had 2 heat loss calculations and two quotes. Both come to over 12k for a 4/5kw heat pump and cylinder system. The flow and return pipework is already in. UFH and manifold on the ground floor. I don't know how they can justify that cost but unless I can find an alternative I am going to have to go with it. I have already had the BUS voucher (which has expired but I am eligible). I have wasted 6 weeks while my useless plumber goes back and forth with the plumb centre and they are quoting to install a pre plumbed cylinder with a buffer tank. I absolutely don't want/need a buffer tank or zoning. I have had to take out a bridging loan to complete the build so every month wasted is costing a fortune so I am looking at all options, one of which is forgetting the BUS grant/MCS and just getting someone to get on with it, hence my question here. I am all ears if anyone can recommend an alternative course of action.The heat loss for the house is 3.2 - 3.4kw. MVHR is installed. It is a 3 bed detached new build with UFH on each floor (the first floor is yet to be done but I have a design and think I will get the builder to do this.)
October 21Oct 21 4kW Hiaer heat pump £2050 incl VAT from Wolseley (you may need to buy an indoor unit also now). You will 2x anti freeze valves an isolated valve and couple of flex hoses. Install direct to UFH manifold.Buy a direct cylinder and just heat via immersion about £500. Any plumber can install your cylinder.About £3k for parts plus labour to install. Edited October 21Oct 21 by JohnMo
October 21Oct 21 Not directly relevant or anything to do with us, but just to introduce Otter South WestWhen we moved here (South Somerset) in Oct '25 we inherited a Daikin ASHP which we decided we'd like serviced and they are one of the local approved co's...But the point I wanted to make was that the guy Chris who came was professional, extremely knowledgeable, helpful and did a great job for us well beyond a service. If you need someone like that then you could ask them if they could help...
October 22Oct 22 Author If I do some form of DIY install is there any issue with getting building regs sign off for a new build? That was my plumbers excuse. Is the BCO going to demand an MCS cert?
October 22Oct 22 1 hour ago, jimseng said:If I do some form of DIY install is there any issue with getting building regs sign off for a new build? That was my plumbers excuse. Is the BCO going to demand an MCS cert?No issue if you comply with building regs! For a heating system you'll likely need a part P spark to sign off electrical work or ask and pay for BC to inspect it. If you're installing an unvented cylinder you'll need that signing off by a qualified plumber. No MCS cert needed but it would likely be accepted by BC as evidence of compliance with regsWhether you can get tradesmen to sign off work they haven't done is a different matter!! BC are obligated to inspect electrical work that you've done but I don't know about pressurised cylinders. Edited October 22Oct 22 by Dillsue
October 22Oct 22 You may may need an MCS noise certificate, but zero reason not to do that yourself, MCS provide all the guidance. But don't provide it not specifically asked. What does you planning permission actually ask for?
October 22Oct 22 Author 9 hours ago, JohnMo said:What does you planning permission actually ask for?I don't think there is anything particular in the planning consent, just a heat pump location specified by the architects and to be installed "by specialists".I have seen the kit list from City Plumbing now and they have specified a 6.5Kw heat pump which is too big for my house. I don't think they took into consideration the MVHR. It seems to me the MCS/Heat pump industry is a mess and it is no wonder people who aren't paying attention end up with poor performing systems.
October 22Oct 22 So nothing stating MCS, position of heat pump is defined by agreed plans, so that's not moveable.So not many variables left except size of heat pump, which isn't stated on plans.As mentioned above Panasonic are good, a small version of that would be fine. But you don't need a lot of the bits they will want to sell you.Feet, flex hoses, isolation valves and anti freeze valves. I would really consider a direct cylinder. Especially if going for PV and/or battery, so you can make good use of ToU tariffs. Edited October 22Oct 22 by JohnMo
October 25Oct 25 Author On 22/10/2026 at 18:53, JohnMo said:I would really consider a direct cylinderWhy is this? The heat pump can heat hot water at at least 150% can it not? I do intend to use TOU and I have a quote for a great economy 7 rate and 32kwh of battery storage so I am hoping to make the system cheap to run. But I also intend to use the immersion element when it is expedient to do so.What is the advantage of a direct cylinder vs a typical UVC?
October 25Oct 25 An UVC can be direct or indirect, so immersion or cylinder coil.A heat pump cylinder can deliver reported CoP of about 5 (Heat Geek Cylinder), we got a reported 3.6 most the time from our normal ASHP cylinder. But when you start to compare the actual electricity input, yes the immersion does consume more but surprisingly not a lot more. We were heating the cylinder twice per day and using about 2kWh per heat (4kWh a day on average), getting a CoP of 3 to 4. Doing it directly via immersion. I was doubtful so did a one test, dismissed it, then a month or so later did a longer test over about 4 day and then left it like that as I wasn't seeing much change in energy usage. The immersion is set to run twice per day it does one heat that takes an hour and other time the immersion comes on for 10 mins a couple of times over 3 hours. So I am using about 4kWhs, somes 5kWh. So really not that much difference in reality On E7 you have a 7 hour spell to heat your water and ideally heat the house, yes you can use the battery but most of the year you can heat the house in the 7 hours. But you will struggle to heat house and heat DHW in the same window with the heat pump. Doing one DHW per day on a small heat pump can take 1.5hrs and that is 1.5hrs less time for heating.Cost, a direct UVC cylinder is £5-600, it can be way smaller than a heat pump cylinder also. A basic heat pump cylinder is £1500 and heat geek ones start at £2500. That cost difference alone buys a lot of E7 electric.
October 25Oct 25 If you are a heavy hot water user (especially if that means you need to heat the water during expensive electricity hours) then heat pump will heating will likely win. But if, as John is, you are able to heat the water overnight (and potentially use solar to heat the water during the summer) then the install would be significantly simpler and cheaper using direct heating.This all assumes you are not getting the heatpump grant. If you want that you have no choice, you have to have the heatpump heat your water.
October 25Oct 25 7 minutes ago, -rick- said:This all assumes you are not getting the heatpump grant. If you want that you have no choice, you have to have the heatpump heat your water.Not really - design wise and plumbing wise the heat pump has to be capable of heating the water - but, of course, once installed, you can set the heat pump to heating only. We do this.
October 25Oct 25 1 minute ago, Bramco said:Not really - design wise and plumbing wise the heat pump has to be capable of heating the water - but, of course, once installed, you can set the heat pump to heating only. We do this.Sure, but if you do that you've still paid for the heat pump cylinder and all the valves/plumbing involved.You are not saving on installation this route.
October 25Oct 25 On 22/10/2026 at 18:53, JohnMo said:As mentioned above Panasonic are good, a small version of that would be fine. But you don't need a lot of the bits they will want to sell you.Feet, flex hoses, isolation valves and anti freeze valves. I would really consider a direct cylinder. Especially if going for PV and/or battery, so you can make good use of ToU tariffs.If using a Panasonic, you don't need flexis and you don't need the feet, just bolt down to a slab, but feet are okay if you haven't got choice, or they sell a metal stand up frame. But also and more importantly, don't narrow down your choices on the DHW cylinder. Also, the Panasonic system by default use the DHW for defrost, although you can switch it to use the CH circuit, but DHW cylinder is a good way to deal with it.40 minutes ago, JohnMo said:A basic heat pump cylinder is £1500 and heat geek ones start at £2500. That cost difference alone buys a lot of E7 electric.Heat pump cylinders from Gledhill have gone down a lot and ex. VAT are around £800 for a good family sized cylinder. For the sake of a few hundred, it's just not worth it long term with a direct. If you ever want to change, you're then talking either a new heat pump cylinder or a plate load kit and you've lost a lot of money compared to just going for an indirect cylinder to being with.On 22/10/2026 at 06:27, jimseng said:If I do some form of DIY install is there any issue with getting building regs sign off for a new build? That was my plumbers excuse. Is the BCO going to demand an MCS cert?Heat pump installations do require building regulations approval, which like with all things you can pay for through your BCO, or use an installer who's registered with a competent person scheme to do this.On 21/10/2026 at 18:20, jimseng said:Both come to over 12k for a 4/5kw heat pump and cylinder system.Is that over 12k after the grant or before it? And what heat pump and cylinder did they specify. And then what control system?5 minutes ago, -rick- said:Sure, but if you do that you've still paid for the heat pump cylinder and all the valves/plumbing involved.You are not saving on installation this route.See above, a 3-port diverter for your cylinder is about £100 and then you just need flow and return pipework to the cylinder, D2 and a sensor back to the heat pump. I don't think a direct cylinder is even a sensible option. Does the OP have family? What's the likely DHW use. For example, we're a family of 4 and have dhw on continuous top up, no schedule through the heat pump. Our dhw cost us a mere £129 for the last year using our average electricity cost, or it would be £220 if using our expensive rate of 30p/kWh I had some more thoughts but something else is distracting me now so forgot......
October 25Oct 25 1 hour ago, SimonD said:you don't need flexis and you don't need the feet, just bolt down to a slab, but feet are okay if you haven't got choice, or they sell a metal stand up frame.Just need to make sure you have suitable snow clearance, same with most modern heat pumps, feet are an easy way to get that. Mine are hard plastic about £16 each. Flexible hoses aren't really needed at all now, but is nice insurance that you aren't going to get any vibration driven noise going into the house. Maybe not an issue when a heat pump is shinning and new, but you never know in 10 years time.
October 25Oct 25 2 hours ago, SimonD said:Heat pump installations do require building regulations approval, which like with all things you can pay for through your BCO, or use an installer who's registered with a competent person scheme to do this.I think the OPs is a new build so building regs should already be approved??I took it that the OP was asking if he could do the install himself, which I'm sure he can with a spark signing off the mains wiring....not necessarily ELV/control though.
October 25Oct 25 1 hour ago, JohnMo said:Just need to make sure you have suitable snow clearance, same with most modern heat pumps, feet are an easy way to get that. Mine are hard plastic about £16 each. Flexible hoses aren't really needed at all now, but is nice insurance that you aren't going to get any vibration driven noise going into the house. Maybe not an issue when a heat pump is shinning and new, but you never know in 10 years time.So just to be clear here, I was specifically referring the the Panasonic installation requirements as you mentioned Panasonic in your post. Other heat pump manufacturers will have different requirements which may stipulate the necessary use of rubber vibration isolating feet and the use of flexis. For example, I wouldn't even dream of installing a Grant heat pump without rubber feet and flexis due to unit vibration - the Panasonics are in a completely different league here.
October 25Oct 25 52 minutes ago, Dillsue said:I think the OPs is a new build so building regs should already be approved??I took it that the OP was asking if he could do the install himself, which I'm sure he can with a spark signing off the mains wiring....not necessarily ELV/control though.Installing a heat pump is notifiable work.
October 25Oct 25 Author So this is a new build. When I say do the work myself, it isn't something I would take on but employ a plumber. My plumber suggested we could do the install under the (what I have now discovered is called) umbrella scheme. However the plumber went to city plumbing and after waiting for 6 weeks I have seen a quote that includes a 6.5kw heat pump, which is too big. So I have no faith in the plumber or city plumbing and I am struggling to just get on with this. I have been quoted 12.k for a system from Installio before the BUS granthas been deducted, which leaves me with a 4.5k bill, which seems like a lot for such a simple job. The flow and return pipes are already in place and I don't need anything sophisticated in terms of control. I can't believe how much incompetence there seems to be in the industry, or am I being unfair? I am at a loss as to how to get this done, wither through the BUS route or via the Umbrella scheme.
October 25Oct 25 If your plumber can do the install (with some help from you?) for less than about £5000 labour only, then I would think that using the umbrella scheme would be the cheapest (and possibly best) option. The one I used was happy to come to North Somerset, and reccomends Panasonic HPs, which seem to be well regarded.
October 26Oct 26 3 hours ago, jimseng said:So this is a new build. When I say do the work myself, it isn't something I would take on but employ a plumber. My plumber suggested we could do the install under the (what I have now discovered is called) umbrella scheme. However the plumber went to city plumbing and after waiting for 6 weeks I have seen a quote that includes a 6.5kw heat pump, which is too big. So I have no faith in the plumber or city plumbing and I am struggling to just get on with this. I have been quoted 12.k for a system from Installio before the BUS granthas been deducted, which leaves me with a 4.5k bill, which seems like a lot for such a simple job. The flow and return pipes are already in place and I don't need anything sophisticated in terms of control. I can't believe how much incompetence there seems to be in the industry, or am I being unfair? I am at a loss as to how to get this done, wither through the BUS route or via the Umbrella scheme.What about the cylinder? What's prepared for the cylinder installation?You say you already have the primaries installed. Who sized them and what size are they? And what's their length?What's the situation with the electrics? Is anything in place or does the heat pump need proper wiring in to the CU, or additional box?As an example, lets just get this priced up very broadly for you:5kW heat pump, lets say a Panasonic. The L-series is the R290 unit and it comes with an indoor bi-block unit and needs 2 power supplies. Price for all bits including controls sensors. Lets assume you're running same direct flow temps across the whole system so no additional bits and bobs - £3800-4000 min up to £4600 depending on the deal you get.250l Gledhill cylinder - £800 ex VATElectrical installation - 2 supplies, 1 x 32A, 1x20A, plus circuit protection - Panasonic manual currently say type A rcd, but they're now recommending type B which can add £100-£150 to the bill each, single supply 4 core from indoor bi-block to heat pump. It's a day's work probably including testing and building regs £700-£1000 depending on cable runs etc. and a decent tidy installation.You'll need some other bits and bobs like anti-freeze valves a 3-port to divert to DHW and other things, say £300-400 minimum.So roughly lets say £6000 just for your basic bit of kit.Labour wise expect about £5000 at least. Why? Reasonably speaking, there's a base to prepare with suitable condensate disposal, pipe runs and fittings, plus pipe insulation, you got a couple of days for the cylinder especially if not going for pre-plumbed, then you have system filling, pressure testing and commissioning, including balancing ufh loops etc. If you have a plumber who hasn't used the kit then expect lots of huffing and puffing and swearing to actually navigate the controls and set the system up properly. Then there's all the MCS admin, OFGEM bus grant, DNO, building regs, commissioning certificate. Proper commissioning of a system with UFH in an energy efficient house takes a lot of time to do it properl.If you use an MCS Umbrella, then the going rate right now is about £1500 for their services to take over the design and commissioning and paperwork.If you were doing this all yourself, then you could just about do it within the BUS Grant figure.By comparison a decent gas boiler, lets say a Viessmann 200-W and cylinder on PDHW and commissioned to run efficiently on your UFH system would cost about £6.5k, if not more.The £12k before BUS Grant is therefore no too bad, in my humble opinion. I'm in the business, am MCS certified and designs and installs heat pumps.So the idea that it's only going to cost you a few grand is quite frankly cuckoo land. But there is also the fallacy that installing a heat pump is just connecting up a couple of pipes. If you read through the majority of posts here on BH from those who have done it themselves, there is a huge amount of tinkering. modification, rectification of their systems, which is part of the learning process. Even if they give the impression it's a 2 minute job, there's a lot of uncounted sunk cost.What were your expectations of cost here?
November 4Nov 4 Author I had been given the idea that I should be able to do this under the umbrella scheme for closer to 9k, but I had in fact decided to go the full install with a Samsung unit and pay the extra. I have now had the rug pulled from under me because I was on the cusp of ordering it and have just been told it has to be Grant or Vaillant. The Grant doesn't do cooling mode (yes I know, caveats etc but...) and has a min flow temp of 25 degrees, which I don't think is low enough for me in mild weather and the Vaillants are so much more expensive I can't justify it. I had no idea getting this right was going to be so frustrating.
November 4Nov 4 49 minutes ago, jimseng said:The Grant doesn't do cooling modeIt does actually but apparently you have to select fan coils as heat mode.50 minutes ago, jimseng said:has a min flow temp of 25 degrees, which I don't think is low enough for me in mild weatherMy heat pump Hiaer will do 20 degs in heating, is it usable, NO. With UFH and a small dT you are likely to be flowing min 24 degs anyway. How thick is your floor screed?
November 4Nov 4 Author 1 hour ago, JohnMo said:How thick is your floor screed?I can't remember things like that!Can you expand a bit more on the "select fan coils as heat mode" bit. I can accept a min 25 degrees flow temp but getting even a couple of degrees cooling in the summer is worth it for me, given I will be throwing away solar energy otherwise.
November 4Nov 4 On 25/10/2026 at 09:43, -rick- said:This all assumes you are not getting the heatpump grant. If you want that you have no choice, you have to have the heatpump heat your water.Is that 100% Correct? I get that the BUS Grant is to incentivise movement away from fossil fuels but chosing to heat HW by direct rather than using a heat pump is an option that allows a reduction in the size of the heat pump to closer align to the Ch needs and a simplification of the circuitry
