Actuators opening when no call for heat
Having a bit of a problem since I turned the heating on again this year. Heatmiser thermostats and using through the hub but one of the zones which consists of two actuators is opening when there is no call for heat. They’re doing this several times during the day and I expect through the night too although I ain’t getting up during the night to check. They don’t stay open very long maybe 10 minutes or so but I’m obviously wasting fuel with it doing this, any idea what it could be?they are sales auto balancing actuators.
Edited by recoveringbuilder
Additional information
I would do a reset and relearn on them. Assume the actuator itself doesn't actually call for heat? So maybe not wasting any energy.
Are other loops switching on or off at the same time?
Actuator definitely opens and pump starts up, no other loops coming on at the same time
So it's nothing to do with actuators - it's a call for heat, because two things are happening the actuators are powered, and the relay in the controller for pump is being asked to close. So best guess is look at the thermostat, as it will be driving the demand
I would agree with JohnMo here. If the pump is firing along with the actuator then something is calling for heat, it is not a stuck actuator. Next time it happens, have a look at the wiring centre and see which channel LED is lit. Worth checking whether the stat in that zone is sitting on frost protection too.
Worth checking all the schedules in the thermostats in case there’s a rogue entry. Also, check the docs -  from memory, there’s some occasional calls to exercise the system for some reason. You can check on the app (if you have the hub) to see which circuits fired and for how long. Bet it’s a rogue schedule.
